  • Guests: 17
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Secondary Winding
Ken M.
Sun Jun 10 2007, 03:52PM Print
Does most everyone here use a kind of homebrewed lathe to wind their secondaries, or is there other simpler ways, because I don't think I'll be able to wind this thing by hand.
J. Aaron Holmes
Sun Jun 10 2007, 04:04PM
What are the dimensions? In the past, I've just put bolts through the PVC end caps on the ends of the secondary form and run these through pieces of wood that I C-clamped to my work bench. Then I just turned the coil by hand very slowly and kept things tight with my fingers. A very large coil probably requires different tactics.
Cheers,
Aaron, N7OE
Zum Beispiel
Sun Jun 10 2007, 04:08PM
I just wound a 30cm long secondary on a 110mm form with 0.25mm wire and it wasn't too bad. It took some 4-5 hours and I didn't use a jig. I was going to, but then I couldn't be bothered to build one.
But if you are going to be using any thinner wire (or a larger form), a jig will definately make your life easier.
Avi
Sun Jun 10 2007, 04:21PM
How about this:
2 blocks of anything, for stands
a wodden stick, stick it across the stands with tape on each end
use some cardboard tube on the inside of each end of your form and punch holes for the stick to go through
add a rubber band for a belt around the tube and use a DC motor out of na old tape player or something that has a belt wheel.
You can add a smaller version for the spool of wire, 2 stands with a stick through it.
Worked for me.
1181492414 580 FT26687 Winder
Tonic
Sun Jun 10 2007, 05:32PM
These links may be useful :
Ken M.
Sun Jun 10 2007, 06:05PM
To answer J. Aarons question it 4"x 18".
Hazmatt_(The Underdog)
Sun Jun 10 2007, 06:29PM
I threw together a coil winder in about an hour and had my secondary wound in about 2 hours.
4" coil form x 36" long PVC drain pipe coil form.
3/8 18 threaded rod, end caps, lots of nuts, two notched pieces of wood to straddle the rod, and something to keep the rod captive screwed down. All mounted on a scrap piece of pressboard.
To power it, a cheapo electric drill from Harbor Freight, and a half wave SCR speed control I made for a friend.
Tape the drill to the pressboard to immobilize it, tape a switch to a workbench, and now you have your hands free to spool and your foot turns it on or off.
I did this on a portable work bench, then had a rod in a vice holding my wire spool. It worked pretty well at probably 10 rpm. If you go too fast you start to get overlapping.
Part Scavenger
Sun Jun 10 2007, 07:40PM
The first one I ever did was by hand it took like two hours and my hand wasn't the same for days... LOL.
I've even seen good designs in Lego and KNEX if you're looking for snap together quick design...
My setup usually looks alot like AVi's
Marko
Sun Jun 10 2007, 08:02PM
Doh..
For bigger ones I use wooden construction with wiper motor spinning the form. and guide the wire by hand.
1181505767 89 FT26687 P1010020
Coronafix
Sun Jun 10 2007, 11:55PM
I used a motor from a microwave oven and some pulleys
from an old washing machine to gear it up.
