  • Guests: 22
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Tesla secondary voltage output...
sparky
Thu Jun 07 2007, 01:41AM Print
I am very puzzled on how to obtain the true RMS voltage off a Tesla Coil secondary on paper. Humm, I thought that typically 1.1kV per millimeter was accurate enough, but obviously somethings wrong when people are getting 6ft (1.6m) streamers - then calling their coil a 500,000 Volt monster???
How does that work?? Sure I've been buildings for a few years now... but I never really cared about measuring the voltage output.
Maybe a few of you guys can shed some light on this issue. Does high frequency current produce longer sparks or is it that due to the higher current evolved in the Tesla Coil - sparks appear longer??
----school project coil------
My Tesla Coil that is being constructed has a secondary of 6.5" X 46" wound with 27AWG , primary is 12 turns 1/2" Copper tubing with a 1/2" spacing between coils. Input is 14.4 kV 3kVA PTs running 2.5X plate rating for 7.5KVA. Capacitor is a MMC brick 46.5KVDC 0.085 uF.
ragnar
Thu Jun 07 2007, 02:31AM
There is "streamer growth" going on... and probably other reasons which would explain why that sizeable Siberian marx generator (seen here: Link2 ) can produce 28-meter/92-foot arcs with "only" 5.2MV.
sparky
Thu Jun 07 2007, 03:20AM
--can someone shed some light on a formula that can determine the output voltage of a Tesla Coil? ...
Hazmatt_(The Underdog)
Thu Jun 07 2007, 04:25AM
mmm....well, I haven't proven it yet, but:
Q_primary = 2piFL / R_losses (I approximate that total as 2-3 ohms including spark gap losses)
Q_secondary = 2piFL/ R (secondary resistance)
both Q's at the same frequency where: LpCp = LsCs;
Magnification Ratio: Q_sec. / Q_primary = Q_mag.
Output Voltage = V_input x Q_mag.
Or you could do the transformer analysis using Mutual Inductance. Since the transformer is an air core resonator, the majority of the transformation comes from Mutual Inductance. You can verify that from the ARRL Handbook.
sparky
Thu Jun 07 2007, 05:43AM
Well, I found out that I'm going to have 2500 turns of my secondary with 115 mH inductance while my primary comes in at 17 uH.
So I calculate:
sqrt(.115 / .000017)
82.24 = transformer V ratio
peak V capacitor discharge (20100 VAC) X 82.24 = 1653181 VAC
Thu Jun 07 2007, 07:07AM
F is frequency L is inductance
Lp is inductance primary, Ls is inductance secondary
Cp is capacitence primary, Cs is self capacitence
sparky
Thu Jun 07 2007, 07:25AM
Thanks! I guess I'm building a 1.6 Million Volt Tesla Coil.
Terry Fritz
Thu Jun 07 2007, 01:16PM
Hi,
See this paper:
ScanTesla can calculate it too far better than anyone cares :o)
Cheers,
Terry
Thu Jun 07 2007, 07:45PM
Sounds really good Sparky,
I've already gotten the million volt mark with my 720VA coil, It's a neat feeling getting there.
Now I have yet to proove the relationship, but from what I am looking over and some I have talked with, it seems reasonable that the relationship holds true.
I would also like to point out that being able to calculate these things yourself serves to proove important benchmarks in your particular system for performance criteria. Being able to calculate the values first off serves to 'narrow the field' of your coil. You could do it the way others do it now, by tweaking a computer simulation, but to build a good coil you have to do both simulations and hand calculations.
sparky
Thu Jun 07 2007, 09:57PM
Did I also say that a group of high school students are putting the coil together... of course I'm the guy who has keys for the safety lock outs!!!
It will make the papers for sure thing and put our high school on the map!
---and make a HELL YEAH, high voltage display!
