  • Guests: 23
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
are these capacitors ok?
brockolicious
Wed Jun 06 2007, 08:23PM Print
brockolicious Registered Member #662 Joined: Sat Apr 21 2007, 06:58PM
Are these capacitors (at the top of the page) ok to use with a spark gap tesla coil? Thanks for the help.
Wed Jun 06 2007, 09:16PM
GreySoul Registered Member #546 Joined: Fri Feb 23 2007, 11:43PM
I'd look on ebay for the CDE 912 series of polyfilm caps. Amazing1 is very over priced on most things.... but in a pinch they would probably work....
ebay is your friend.
rell.com and digikey.com are good too.
Wed Jun 06 2007, 09:29PM
You can get doorknob capacitors on Ebay as stated above for half the price. I use a Maxwell pulse capacitor.
Coronafix
Wed Jun 06 2007, 09:50PM
Ceramic capacitors are generally not recommended to use for
a spark gap Tesla coil.
sparky
Wed Jun 06 2007, 10:44PM
Good deal on the tubular 0.1uF 20kVAC rated caps from Amazing1 --- those kinds of caps can be in the $1000 + range!!
Shaun
Wed Jun 06 2007, 11:43PM
No, definitely do not use ceramic caps of any types, they will not stand up to the high pulse of an SGTC. Go with the CDE caps; they're known to work and won't break the bank (usually $3-4 apiece)
Thu Jun 07 2007, 01:42AM
$750 is a good deal on a 0.1uf 20kv cap? i just got 4 194uf 10kv caps for the same price roughly(for all 4)....I gather these differ significantly from pulse/energy caps... but wow, what a price/Joule increase.
-Doug
Hazmatt_(The Underdog)
Thu Jun 07 2007, 01:44AM
This is a 720VA Tesla coil using TDK 2nF Doorknobs. I have not seen any other coiler yet to get 38" arcs from 720VA input power.
I could not push the envelope as far as I have with any other capacitor. The TDK 2nF 40KVDC capacitor does not even bat an eye at the pulse power, and they are designed SPECIFICALLY for HIGH PULSE. I would love to see someone come up with a design that could best these capacitors. The button terminals are connected directly to the Titanate for minimal inductance.
As a designer I don't see a better alternative, that is if you can afford these buggers.
Strontium Titanate doorknob capacitors > ABSOLUTELY YES they are hardcore performers
MICA >>> NO NO NO. The old Sprague 4nF reconstituted Mica Doorknob Capacitors SHORT at power levels exceeding 300W. I Have them, I have tested them, so don't even go there.
I'm posting this because some of you guys are replying without the experience. I have the experience.
1181180691 135 FT26444 Tc13mdk
Coronafix
Thu Jun 07 2007, 03:08AM
Just look for polypropylene high dv/dt capacitors.
These work beautifully, low loss and reasonably priced
compared to the high end stuff like the TDKs.
