  • Guests: 30
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
Modifying the secondary
Sat Jun 02 2007, 12:47PM Print
Some of you may have seen my attempt at a Tesla coil with a 15kv/60ma power input and a 6"x29.5" secondary. I don't want to reinvent the wheel by winding numerous coils so I thought someone here may have already tried what I am going to ask:
If I retune the coil each time, what can I expect to happen if I use a 7" x 35" secondary? Since spark length is a function of the square root of the input power does this mean that there are various secondarys that will yield similar streamer lengths?
Brett Miller
Sat Jun 02 2007, 03:46PM
Brett Miller Registered Member #593 Joined: Tue Mar 20 2007, 12:32AM
The Freau formula, 1.7 * SQRT(wallplug power) assumes a pretty efficient system which has most parameters optimized. That's why I think most people consider it guilty of overestimation. However, since it is quite possible to achieve the spark length predicted by the formula, and with some work, even beat it...I don't really agree that it is overly optimistic.
Component parameters of a disruptive coil, like most TC topologies, involves a balancing act to a large degree. For instance, using a wider, taller coil, with thinner wire allows you to use more turns on the primary and a smaller tank cap. This lowers the primary surge impedance and thus brings the gap losses down. However, taken to an extreme, this same technique will create a lossy secondary that could very well cancel out any advantage given by its design.
If you haven't seen this, you should check it out. It's John's efficiency theory:
...but it looked like your coil was working great as is (except for the internal arcing), so good luck!
-Brett
