  • Guests: 32
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
new coilgun q's about barrle and progetile size
JoeDarkon
Mon May 28 2007, 09:19PM Print
JoeDarkon Registered Member #485 Joined: Sun Jul 09 2006, 01:14AM
currently i have have 2 scrs so i am limited to 2 stages. the caps i have are 4 400v 3900uf and one 450v 2400mdf (same as uf right?) i need to make a new barrel and was wondering about what size and material i should get at the local store i saw copper and galvanized steel and pvc i think the pvc is out of the question because of the thick walls for the metal i can cut a line down to reduce eddy currents. and then the projectile size will depend on the barrel
Tue May 29 2007, 04:59PM
At those power levels and capacitances I would go for a large projectile. The pulse time will be long, so a small/light projectile would be in the target before the current even gets to peak. And anything small would just saturate in no time. I haven't seen it done before, but try a heavy (100 gram like) projectile. That should give you efficiency and power to smother soup cans. shades Even a meager 1% efficiency would move 100 grams to 15m/s. After all, isn't a coil cannon more fun than a coil gun? Personally I would go for PVC, but I don't know if it comes strong enough or thin enough, so you'll probably have to use metal. The less conductive and magnetic the better, as eddy currents will become a problem. I'm not sure about barrel size, but maybe you should suit it to fit your projectile?
JoeDarkon
Tue May 29 2007, 06:11PM
thanx for the input but i dont know what size a larger projectile would be... half inch in diameter or more?
Tue May 29 2007, 06:53PM
I don't know either. cheesey Just look for something big. You could try a long rod, but that would also require a long coil I think. I've never tried a projectile longer than the coil, so it might work just as well with a shorter coil. A coil longer than the projectile isn't good though.
Electroholic
Tue May 29 2007, 07:48PM
its not really that high power, i had a 200J single stage firing 3/16 dia projectiles that weight less than 4 grams.
quarter inch should be a good value to start with for you.
and coils should be the same length or slightly longer than the projectile for better coupling.
JoeDarkon
Tue May 29 2007, 07:49PM
how large in diameter is ur largest projectile i think im gonna go for half an inch
Electroholic
Wed May 30 2007, 09:08PM
im using 10/32 cold roll steel, with 1/64 Wall thickness 11/32 O.D. brass barrel. 1050V 2400uf single stage.
