  • Guests: 16
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
What to do with these IGBT Modules (FMG2G300LS60E)( hopefully Tesla coil related)
Danielle
Wed Sept 19 2007, 06:26AM
Danielle Registered Member #632 Joined: Mon Apr 09 2007, 01:09AM
thats Td(on):.23us , Tr: .21us, Td(off): .43us, Tf:2.43us
so is it possible because I would love to pump more power into the coil I dont really cair about the losses unless its enormous and I will build the brick driver to drive the gates as fast as possible
Wed Sept 19 2007, 05:28PM
I would still say they are far too slow. You will end up switching enormous currents because of that turn off time. Also, because the turn on and off are so very mis-matched, you will need to add deadtime to the gate drive so you dont have shoot-through. Looking at the graphs on the datasheet, it seems you cannot improve Toff with a better gate driver (its pretty much fixed at 2uS).
FYI, the CM300 IGBTs i use at 40khz have something like 300nS Td and 350nS Tf which outperforms your IGBT by a good margin, and i still consider it to be less than optimal running these things at 40khz.
Danielle
Thu Sept 20 2007, 01:48AM
could I run those IGBTs (CM300)with my coil because I may be able to purchase 2
Fri Sept 21 2007, 12:32AM
Well umm, i suppose you could but you will need to build better gate drivers etc... which is quite a project. Just dont think its gonna be easy and fast to put together (its a large step up from the simple DRSSTC setup you used). Its really overkill too, but that isnt a bad thing necessarily.
Bennem
Fri Sept 21 2007, 05:45AM
Why not try and get hold of some HGT1N40N60A4D mini brick igbt's
which would be a ideal for your DRSSTC driver, and will make your coil more durable
than the ones you are using now.
they are harder to find these days but not impossible,
folks are still selling them on ebay etc.
or the slightly less rated HGT1N30N60A4D which is more readily available.
Steve Ward uses a full bridge of them in his DRSSTC1 and gets some 80 plus inches of spark.
As Steve said, upgrading to CM bricks involves more complicated driver circuitry needed
as well as seperate isolated power supplies to feed the aditional drivers.
Mel.
Danielle
Fri Sept 21 2007, 11:10PM
thanks I think I am getting a 400A 1200V 30-60Khz rated dual IGBT brick pack if no one out bids me this should be nice. I will start to work on constructing the improved gate driver, but am thinking of making it a removable module so I can use it on multiple projects, It would be to take 120VAC then bring that switched like I have seen for the isolated PSU and the gate driver input, then just have plugs for all the gates. I was only thinking as I am also working on an extreamly advanced all in one fiber interrupters, that this upgrade would be nice. My only other questions are , is there a more reliable and tunable logic circuit I should use, and how difficult would it be to set up an under voltage lockout and a no signal/out of phase signal lockout so if the gate driver fails it wont bring both IGBTs high? The bricks are $$$$
Bennem
Sat Sept 22 2007, 06:04AM
For examples of under voltage shut down circuits,
take a look at Dan McCauleys site under his 'Advanced
self resonant driver' he uses a simple op amp/comparator
ic and a few other components.
i beleive Steve Connor also uses a similar circuit on his DRSSTC.
