  • Guests: 32
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
What to do with these IGBT Modules (FMG2G300LS60E)( hopefully Tesla coil related)
Danielle
Sun May 27 2007, 09:11PM Print
I have 10 now 8 ferchild 300A 600V IGBT modules FMG2G300LS60E, and want to do something I am giving away 2(already did) but was thinking of making a OLTC with some of them what should I do with the others?
1180300273 632 FT0 Img 0192
1180300273 632 FT0 Img 0193
Mon May 28 2007, 03:11AM
well, since they are quite slow--fall time of 5us!--you might be better off making a monster 8 stage coilgun with them, or a welder...
Danielle
Mon May 28 2007, 04:03AM
would they be usable in a OLTC?... how would I make a welder?
Brett Miller
Tue May 29 2007, 04:47PM
Brett Miller Registered Member #593 Joined: Tue Mar 20 2007, 12:32AM
Daniel,
I think your thread might get more attention if you had "IGBT Modules" and "FMG2G300LS60E" in the title.
Obviously I too would like to know if people on here have done anything cool with those Fairchild half-bridge modules.
-Brett
Tue May 29 2007, 06:54PM
I have some similar but lower current, higher voltage half-bridge packs
You can use two packs, one per pack, to make a CFPR/ZVS/Royer invertor;
using a ferrite inductor/transformer you can make several kV rms at 20+ kHz
to power a dc SGTC
or a large C-W multiplier
which could be used for a Marx generator, Jacob's ladder etc.
OR
using an air-cored copper-tubing inductor as an SSTC primary (below 100kHz)
OR you could use them (one per pack) for a coilgun
OR as half- or full-bridge induction heater.
Basically you can use them for almost any hv project.
Tue May 29 2007, 10:08PM
Have you seen Terry Fritz's SISG concept? If I were you, I'd be looking at trying to make a SISG out of a series stack of bricks. It would be a first.
You can make an OLTC out of 600V IGBTs, but the performance isn't too spectacular. You really want over 1200V.
Danielle
Tue May 29 2007, 11:02PM
The SISG sounds interesting what I have seen on it so far is that they sires up a bunch of IGBTs as the spark gap is that right if so this would make a hell of a big coil how long arcs could I get with 2 MOTs.
Brett Miller
Wed May 30 2007, 02:49AM
I'm pretty sure Mark Dunn has gotten at least 40 inch sparks with a dual MOT SISG system, but that info is from stuff I read regarding what he and Terry were working on last year. They may have beaten that by now. I know Finn got even longer sparks with a brick SISG (BRISG). I am working on a small SISG prototype just to make use of some TO-247 1200v 75A IGBT's I had laying around that I mistakenly bought even though they lacked the crucial anti-parallel diode. I found a pretty beefy diode on Digikey (600v 50a ufast) that I am going to put in my SISG board. Of course I'm using the 40n120 TO-264 fairchild diodes in my DRSSTC halfbridge. So I have some pretty serious projects going in parallel, plus I wouldn't mind having an OLTC around too...
-Brett
Danielle
Wed Sept 19 2007, 03:38AM
ok so I am bring this thred back just for one question:
can I use these in my DRSSTC it is running at around 60Khz and my small IGBTs arnt cutting it when I try to push it past 900A lol yes I did get 72" arcs and would like to have something a bit more durable. if I run it at a long on time and long off time do you think I would increase the probibility of using these reliably, the only problem is that they are really slow.
edit
I calculated the max switching frequency for one cycle to be 303Khz but I think that a 60Khz switching time at 1-2% duty cycle should be ok.
Wed Sept 19 2007, 05:21AM
No, 60khz is still fast for these IGBTs. Someone mentioned 5uS turn off time, which is enormous even at 10khz.
