  • Guests: 26
Alexandre (32)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
SGTC Component Spacing Questions
ArcLight
Wed May 16 2007, 10:13PM Print
ArcLight Registered Member #341 Joined: Thu Mar 23 2006, 07:41PM
Thanks to the information that I obtained on this site and others, I have built my third coil. This is a 3.5” coil with a 5:1 form factor using 24 AWG wire. The primary is 11 turns of .25” copper tubing on .5” centers, tapped at ~10.5 turns. The top-load is a 3.75” by 17.75” toroid. The gap is a blown static gap (like a sucker gap, but with positive pressure) set at .20”. The MMC is 10 (5 in series on each side of the primary) .15 uF CD 942's with the whole thing powered by a 60mA/15kV Franceformer NST protected by a Terry filter (thanks Terry.)
There is no more than about 4' of wire to connect all of the components, 12 ga. solid copper from NST to Terry filter to spark-gap and 10 ga. stranded between caps, gap, and primary.
The problem that I'm having concerns the caps and the bleeder resistors. To make repairs easy I mounted the caps with brass screws on strips of poly cutting board. To keep leads short the caps were mounted end to end so there is only about .5” of lead between caps. The problem is trying to keep the bleeder resistor leads short while reaching around the cap. I allowed 5/16” between the cap and the resistor and have found that this is not enough as I have had 4 arc overs.
My questions:
1. What is the minimum safe distance between cap and bleeder or would it be best to just mount the bleeders on the other side of the poly for the minimum amount of connecting wire.
2. Is there a minimum distance that the MMC should be from the primary coil due to the magnetic field? Does it matter if the cap bank is parallel or perpendicular to the primary?
3. Is there any advantage to mounting the gap close to the primary coil in an effort to get the magnetic field to help quench the gap?
Regards, ArcLight Link2
Tetrafluoroethane
Thu May 17 2007, 02:03AM
Tetrafluoroethane Registered Member #127 Joined: Fri Feb 10 2006, 03:36PM
1) I like to keep my bleeder resistors airborne entirely and mount them on the opposite side of the board to which I strap the caps. That gives them plenty of space to heat up and not melt anything and keeps a nice insulator between them and the caps. In normal operation they really shouldn't heat much anyway, but I still like to give them room to breathe. From my experience 1/4 inch seems to be just fine. I don't worry about the bleeder resistor lead lengths since they don't really do much when the coil is operating (in the way of providing power). I don't think their inductance (I assume that is why you want to keep them short) even matters (one of the more experienced guys here might be able to verify/correct this notion).
2) My 900 watt coil had the MMC right below the primary (about 8" under. I never noticed any difference in performance (and nothing blew up due to transients). Originally it was about 16" away, but I moved it when I added a 2nd NST to the setup. And I was even using the less durable CD 940Cs. cheesey
3) Interesting concept. I never thought of it, but my initial guess would be no. I would think the magnetic field might push the arc around a bit, but not help it quench. But if your setup can be readily changed around try it and post the results.
Good luck with your quest for streamers.
Hazmatt_(The Underdog)
Thu May 17 2007, 02:23AM
My capacitor bank ( 40KV TDK caps) was mounted on two sheets of circuit board and etched so that there was an island of copper on both sides, and then the caps mounted to it to form the bank. I didn't notice any performance difference between it standing upright and lying on its side with the system, other then one important factor, the leads to the bank. Keeping the leads short and heavy is really important for performance.
There is one major issue I had with mounting the cap bank under the flat primary though, and some issues with the cap arrangement. The problem is that if you don't coat the copper, it tends to arc over, even with a 1" margin on either side. I had flashovers from plate to plate, and flashovers from my primary to plate. The major cause of the primary flashovers was due to a simple factor, how I mounted my primary. The primary coil was held down by little plastic wire tie holders that were screwed into the wood coil support, so the arc started from the tip of the screw to the plate, about 3" distance. Once I put Corona Dope on the plates, the arcovers ceased.
I think in SGTC keeping everything short and close together is partly important, but when you get to about 3" separation you see some pretty nasty arcovers, so you could increase the distance or use insulating coatings, teflon sleeve, the usual stuff.
There are some pictures of my setup around here and on the old forum too, I can't really find anything at the moment, I have too many files spread out.
Coronafix
Thu May 17 2007, 03:19AM
Mounting the primary with metal screws is just asking for an inefficient coil
and perhaps other problems like arcing over. There are many ways of
mounting the components without using screws, it just takes some imagination.
1. Mine is mounted one on each side of versa strip board. Had to dremel of some of the
copper strips to make it arc safe, but no problems.
2. Concerning the arc over, I just measured the 15kV 60mA no load spark and
doubled it. this should be a safe minimum distance for all components excluding secondary.
I did have one arc over on my system because one of the bleeders had
some of the enamel scratched off on it, so it arced and burnt it out.
3. I highly doubt that the magnetic field would be anywhere near strong enough
to quench a spark gap.
Thu May 17 2007, 06:19AM
For one, the primary was mounted on little plastic wire tie hold downs, and two, metal screws has little effect on efficiency, and if you need some proof, its right here:
1179382778 135 FT25281 Tc13mdk
1179382778 135 FT25281 Tc14mdk
Coronafix
Fri May 18 2007, 02:53AM
Looks good Matt, but think of the spark length you could have gotten if
you hadn't have used those metal screws. tongue
Fri May 18 2007, 04:16AM
Sure, whatever you say. You worry about the screws, I'll worry about the poor coupling, which has an impact of several orders of magnitude greater then the hardware.
ArcLight
Fri May 25 2007, 02:44AM
Thank you all for your responses. Please forgive my tardiness in responding, an unexpected illness and then death in the family several states away required my presence, so I have been computer/internet deprived.
Tetrafluoroethane, you are correct that my intent is to minimize the amount of wire in the primary and optimize the placement of components in an effort to limit stray inductance. I have now done as you suggested and mounted the resistors on the other side of the poly from the caps.
Had another cap and resistor fail last night, but it may have had a manufacturing defect beings as it failed immediately on power-up. Still, I'm beginning to think that I'm going to have to use two strings of 20 caps rather than one string of 10 if I'm going to reduce the number of failures. It still seems odd that I have had 4 failures on one side of the primary coil and only one on the other.
Hazmatt, I think that I'm going to bolt the MMC bank directly to the sparkgap, then the only wire in the primary circuit will be between the caps and the resistors in the MMC, and the MMC and the primary coil (remember that I have half of my caps wired to either side of the primary so both banks will be bolted to either side of the gap as well.)
Goldsphere, as noted above I'm now mounting my bleeders on the opposite side of the poly from the caps. I have no way of knowing how well my gap quenches. I believe that it quenches relatively well only because I get decent arcs and have very, very little erosion of the copper contacts. The magnetic quenching question was kind of mental masturbation (just can't pass up the possibility of something for nothing). I agree that there is probably little chance of enhanced quenching, but every little bit helps and I just want to be sure.
Regards, ArcLight
Coronafix
Fri May 25 2007, 03:03AM
ArcLight wrote ...
Is there a certain reason why you have decided to do this? rather than have one bank?
It seems to me that the two banks would have to be well balanced. This might be the
cause of the failure on one side of the primary.
Maybe someone else can shed more light on this?
ArcLight
Sat May 26 2007, 01:09AM
Goldsphere,
The short answer is I believe that Tesla did it that way.
The longer answer is that at first I didn't think that it would make any difference how the tank cap was integrated into the primary circuit of a Tesla coil. But, after reading some papers about Tesla's “equi-drive” and magnifiers I decided that I would divide the caps between the opposite ends of the primary coil and spark-gap.
While still using MOTs and salt water caps with the gap parallel to NST. Gap, caps, and primary is series, not equi-drive. I found that the side of the gap without caps got much warmer than the side with caps (about room temperature on one side and guessing about 300 F. on the other.)
After changing the MOTs to a 15Kv/60Ma NST and splitting the caps (now MMCs) evenly I still have some slight uneven warming of the gap, but it's much better than before. I think that with uneven splitting of the caps, I may be able to spread the load more evenly across the primary and get longer life for all components.
Regards, ArcLight
