  • Guests: 19
Alexandre (32)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
DRSSTC Update
gentoo_daemon
Wed May 09 2007, 05:31AM Print
gentoo_daemon Registered Member #512 Joined: Sat Feb 10 2007, 05:42PM
I finished that half bridge DRSSTC. I ended up going with 15 strings of 4 of the CDE caps. Everything worked fine. The ti drivers actually drove the bigger IGBTs. Resonant freq was about 41 kHz
here is a photo of the coil and my project partner, Leslie.
I ran at 1/3 power for a while. ( got small arcs). Everything was fine until i turned up the power to max. That's when I think an arc struck my MMC terminal and there was a flash by the IGBTs. :( Now I had a short on the input of my coil. So i took my bridge apart to find that the IGBTs were indeed shorted across emitter and collector. Is this usually the case when you overvoltage them?
I had the driver board well protected, but the half bridge and the mmc were pretty much exposed.
I'm going to upgrade to the pwrx cm600 IGBTs, a full bridge this time.
Wed May 09 2007, 06:29AM
Well, these things do tend to blow up when everything isnt perfect (and even still when they might be). I doubt it was simply an arc between the MMC and bridge... its never *that* simple. The flash you saw was very likely just the IGBT failing (unless your MMC was mounted with .25" of the IGBTs). I hope you didnt have the impression that these things were easy amazed .
Anyway, good luck with the trouble shooting. Larger IGBTs might just be what you need. You should be measuring your primary current during these tests to make sure things arent wildly out of control. Being out of tune will make small sparks yet run enourmous current through the IGBTs.
gentoo_daemon
Wed May 09 2007, 02:23PM
Steve Ward wrote ...
Yeah I noticed that when i first turned it on. I had the OCD pot set to 2 volts, and my LED was blinking constantly yet there wasn't really any output. After it was tuned, this went away.
gentoo_daemon
Wed May 09 2007, 04:41PM
I meant there was an arc from the toroid that struck the mmc terminal since it was sticking out quite a bit.
Wed May 09 2007, 05:19PM
Oops, i just misread your post. That could indeed cause the failure. So the sparks were that long already huh? Sounds good!
