  • Guests: 24
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/30 BlakFyre (36)
04/30 SENTRY (31)
05/01 Shaun (34)
DRSSTC Build
colin heath
Thu May 03 2007, 04:59PM Print
colin heath Registered Member #123 Joined: Fri Feb 10 2006, 12:58PM
Hi All,
I have started my 4th DRSSTC build. The whole base is going to be 20mm thick white Acetal. I have attached pics of the base squares along with what will be primary former top and bottom rings. Next pic is a slab of Siemens IGBT's I will be using some of. Very kindly on there way to me thanks to Chris Hooper aka (plexi master). Thanks Chris.
This will be half bridge but running off 600VDC. around 400-500nF Tank cap. 6" secondary. not sure what drive circuit yet. May even go PLL just for fun.
I have started before finishing my gap coil as 1 project at a time makes too much sense.
Cheers
Colin
1178211586 123 FT0 Drsstc 1
1178211586 123 FT0 Igbt2
Bennem
Thu May 03 2007, 07:21PM
Bennem Registered Member #154 Joined: Sun Feb 12 2006, 04:28PM
Hi Colin,
I suppose its out of the question to ask if
it will be completed for this years Derby 'thon?.......lol
I've seen video demos of your DRSSTC coils 1 and 2 in action,
haven't seen your DRSSTC 3 yet.
Whats the res frequency of your new coil?
All the best with your new project! ..... smile
Marko
Thu May 03 2007, 08:18PM
Wow, those look like some pretty serious IGBT's.
Why only a halfbridge? Fullbridge is 2x the fun shades
Dr. Drone
Thu May 03 2007, 08:31PM
shades
colin heath
Fri May 04 2007, 07:37PM
Hi FirkAll,
Paul the only DRSSTC I have taken to a thon was in a terrible state!!! I was the first in the UK to try and didn't even know how to build a basic coil really >_<
The next 2 i sold before I got to thon!
Firkragg,
Those IGBT's are nice and i am using them seeing the results Chris had from them! Full bridge is fun and i might go that way.
Cheers,
Colin
Tom540
Sat May 05 2007, 03:10AM
Tom540 Banned on 3/17/2009.
What are the part numbers on thoe IGBT'S I'd like to use something similar on my old coil when I rebuild it bigger.
