  • Guests: 26
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
DC no-resonance
attune
Sun Feb 26 2006, 06:19PM Print
attune Registered Member #259 Joined: Sun Feb 26 2006, 05:57PM
I am building a resonant DC tesla coil, and am very close to completion.
  • 2500v MOT, 4x voltage multiplier (10kv 80ma)
  • ARSG
  • 24kv 0.0125 uf cap, 0.15 snubber cap mmc
  • 4" secondary
  • 2 toroid topload
  • Charging reactor, 4 MOTs with secondaries connected in series, open primaries, and 'I' blocks cut off and separated by 1/8" from the 'E' block.
I connect everying with bolts and 6 awg wire. I use a small variac to control the arsg. So far the output is almost non-existant, only a few inches. I have tested the supply with 9v AC, and got 700 volts out, which is what I should get, but the capacitor only chargeds up to 700v. With the DC resonant system I build it should be charged up to 2x supply voltage. What gives? This means the cap bank is only charged up to 9000v. Does anyone have suggestions? Help!
Roger
Sun Feb 26 2006, 06:58PM
Roger Registered Member #221 Joined: Mon Feb 20 2006, 05:36PM
You might want to try using a rotary spark gap in series with your static gap.
On small DC resonant systems with static spark gaps I have had interesting results using the secondary of a neon sign transformer as a charging reactor. You don't get real long sparks but your "breaks per second" is real high. So high that the coil makes a wining noise and puts out a flame like spark. smile
Roger
attune
Sun Feb 26 2006, 07:03PM
I am using an asynchronous rotary spark gap...
Sun Feb 26 2006, 08:07PM
Hmm, what is your BPS?
how is working the ARSG, it makes big flames?
And what is snubber cap?
Take off completely the "I" blocks and try again
attune
Sun Feb 26 2006, 09:03PM
I am not certain what my BPS are, but I with my configuration I am pretty sure that it is 100-500. The sparks in the gap are much smaller and quiter than they should be >:(, and it does not always spark ( I can see breaks in the spark) even though the gap is set very close. I will try taking off the 'I's entirely.
Sun Feb 26 2006, 09:14PM
Do you have a de- quing diode ? it is needed to stop the extravoltage to be drained back into the power supply.
Is your design similar with this?
http://www.scopeboy.com/tesla/tc2schem.html
Sun Feb 26 2006, 09:22PM
For dc 'resonant' charging,
the voltage across the primary capacitor looks like 1/2 a sinewave
because it is!
The time between 'bangs' needs to be more than the time for half a cycle of sinewave at frequency=1/2.pi.srqt(Lcharge.Cprimary)
I guess that four MOT secondaries in series is too high an inductance for normal dc charging to work.
Sun Feb 26 2006, 09:31PM
This would explain the quiter arcs in the gap. The L tends to make the arc more continuos, without the well known cracking sound.
Nick Berndsen, member on this forum, used a DC resonant charging too with only two MOT cores, so they keep well. Here the link:
http://www.geocities.com/**link**/TC3.html
and the source:
http://www.geocities.com/**link**/TC3ugly.html
So you have place to move, with lower inductance.
attune
Sun Feb 26 2006, 10:53PM
Sounds like good advice. I will try it right now. So let me get this right, I won't be able to measure the doubled voltage?
Mon Feb 27 2006, 12:09PM
The voltage won't actually double until the spark gap starts firing.
The thing about needing a certain maximum inductance for DC charging is a myth. No matter how big the inductance is, the tank capacitor still charges to twice the DC supply voltage. This has been known since the 1940s. However, using a small enough inductance to give discontinuous current may make it easier for the spark gap to quench.
