  • Guests: 27
Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Feeling at home, new coil
ragnar
Tue Mar 27 2007, 07:30AM Print
Hi all,
here's the first coil I've had running successfully in my apartment (rite of passage for me ;) -- he goes at ~9MHz, and draws about about 120V, 1.5A.
Class-E topology, single IRFP450 as switching device. It makes nice flappy white flames when discharging near a groundplane, though I'm having reliability issues with the MOSFET (a 'mere' gate drive problem as usual).
1174980784 63 FT1630 Bwcoil1
1174980784 63 FT1630 Bwcoil2
1174980784 63 FT1630 Bwcoil3
Tue Mar 27 2007, 08:06AM
Hi matt!
The coil is pretty. And performance looks darn good considering the mosfet you are using at 10Mhz and 200 Watts! I personally wouldn't expect very much more of system like this at that frequency. suprised
Lately I had some new ideas for high frequency gate-drive and switch design wich are still confidental.. I just don't want to stack more unfinished projects sad
Tue Mar 27 2007, 02:03PM
Glad to hear the move went ok smile
You make 9mhz at 200w seem easy, I remember when 4mhz using 'real' fets was a big achievment!
keep up the good work!
ShawnLG
Tue Mar 27 2007, 03:57PM
9Mhz is very impressive. You got 4.56Mhz to go to get to 13.56Mhz barrier.
ragnar
Wed Mar 28 2007, 03:24AM
I'm really hitting a "ceiling" with the IRFP450... it's gate capacitance is just too high to swing, and I feel its output capacitance is also a limiting factor (I'm not even using a shunt capacitor =P)
My next goals include some off-line work. I'd like to get a small coil going in class-E from rectified mains (340Vin, here), which implies at least 1500V devices (or clever combination of a few 500V devices ;)
And I'm running out of IXDD414s... I have only two left =(
Dr. Shark
Wed Mar 28 2007, 05:40PM
Wow, another fine coil you made there!
I gave up playing with Class-E coils a while ago because I ran out of patience tuning them, but I should try again... Do you feel like drawing up a little diagram of how your circuit works? I guess you are resonating the gate capacitance, so it would be nice to know a couple of ball-park values for the components to use there.
WaveRider
Fri Mar 30 2007, 08:14PM
My compliments BP... 9MHz is an accomplishment! With all the harmonics you are probably emitting on 27 MHz, I bet a few CBers are squealing! ;)
Sat Mar 31 2007, 11:29AM
Nice coil, BP! and nice apartment too. RFI can be a problem, but if your local CB scene is anything like mine, it needs all the jamming it can get wink
Sat Mar 31 2007, 04:14PM
Hi guys..
Regarding harmonics, TC's aren't actually all that efficient radiators.. but even if little EM escapes it can still create a mess! Coupling of RF to mains is probably a much bigger problem.
I'm just curious, how efficient it roughly is? I can imagine your mosfet dissipates quite a lot of power considering your heatsink size.
ragnar
Mon Apr 02 2007, 01:01PM
Much better...?
Do I dare apply power?
1175518861 63 FT22547 9mhzdrv1
1175518861 63 FT22547 9mhzdrv2
