Registered Member #162
I have finally decided to join the modern world and I'm building an Interruptor for TC use with a PIC microcontroller.
(Technically it's my second project as I made a led flasher by copying circuit and hex code direct from the internet, without understanding the hex code. It worked so I feel a little more confident to proceed)
I sampled a PIC16LF84A (for the led flasher) and a PIC16F690 for this project and bought one of those JDM programmers off eBay I should have got an original PIC programmer from Microchip the debug facilities would have been worth the extra too late now - carry on regardless.
The current design is for a 20 char x 2 line lcd display with pushbuttons for;
Ton The on time for gating TC operation in DRSSTC mode etc. to be adjustable from 1 to 999 us Toff The off time between ON times, 1 to 999 us PPP Pulses per packet. From 1 to 999 ON/OFF pulses continuously PRF Packet repetition frequency, how often a packet of pulses is produced, from 0 to 999 Hz
RUN Press and hold to produce output, release to modify variables
MCLR in case of latch-up etc.
So far I have done the (for me) easy part, the electronic board; here are some photo's
The black connector is for 0V and +5V The blue connectors are for 0V, RA2 the output, and RA0 and RA1 as yet un-assigned. The yellow blocks are capacitors (100nF MKT) are part of the switch de-bounce, since I don't fancy programming de-bounce software yet, and they make convenient locations for labels.
I shall make a second board for 230Vac to +5V regulated, a TC4421 output buffer, and an invertor for the EL backlight.
I haven't even worked out how to get to the assembler in the Microchip MPLAB IDE software yet, so progress will slow down for a while ! Hopefully updates are to come
I may do that, but initially I will be running the interruptor far from the TC by using a TC4421 to drive a long 50 Ohm co-axial cable, and maybe I will run the interruptor off a 12V VRLA Battery for good isolation. This together with the need to continuously press the RUN button, will hopefully keep me from getting too 'adventurous' near the running coil. Two-person operation required for close proximity 'testing'
I've considered using fiber-optic coupling but can't be ar5ed.
If I do have problems after that I'll put it in a metal box.
I actually remembered to make allowance for mounting holes with this project! I often end up with a board layout that results in double-sided-tape for mounting
Registered Member #33
I have been working a bit with something very similar, it was going to use a 2x16 LCD/VFD and some buttons and a rotary encoder for input. This was going to be for SSTC stuff exclusively, I was going to make a DRSSTC version later. On and off time was going to be adjustable between 0.0 and 999.9ms and it would calculate and show the frequency and duty cycle. I managed to finish all of the display handling code, and I had the main timing loop all figured out. It was going to run at 4MHz, 1µS instruction cycles, the main loop was going to be 100 cycles long, and it would take care of reloading counters and checking buttons. As soon as it detected input, it would disable the output, modify the appropriate registers, show the new on/off time, duty cycle and frequency and then go back to the main loop with the new timing. Until I realized a normal 555-based interrupter would do just as fine, and that sparks from running halfwave rectified mains uninterrupted look much nicer anyways.
I'm still considering making one for DRSSTC duty, where close control of the interrupter timing actually matters.
If you need any help with display driving routines or things like that in PIC assembly, PM me.
BTW, I think 1-999ms would be more appropriate for Toff in DRSSTC duty.
I may not have clearly explained the proposed timings, a little diagram;
This is shown for example with PPP = 4 pulses per packet
The idea being to set Ton (e.g. 200us) as large as possible without over-current in the output transistors Then give a small break (e.g. Toff=100us) Then have PPP number of these pulses in a 'packet' to grow the streamers (e.g. 4) And finally to have PRF packets per second (e.g. PRF=100 packets per second) If PRF=0 then there will be only one packet per press of the RUN button.
Registered Member #575
I have done something very similar just using a 555 timer, but I have always liked look of fancy LCDs so I’ve like to have the circuit schematic if you don’t mind.
Registered Member #89
Well, great work..
I have one simple reason why I dislike metal shielding boxes: they give me shocks as I'm in proximity of the coil!
If I want shielding, I just use aluminium tape on inside of a palstic box and ground it. And my current interrupter withstiff layout seems like it doesn't even need it.
Registered Member #30
Looks great, Sulaiman. I have made an interrupter with a PIC before (a PIC16F870 IIRC) but it was for a very specialised application. The Toff had to be pseudo-random, the Ton didn't matter, and the number of pulses per burst had to be adjustable by a trimpot.
So I just wrote code to cover this special case, and never got round to trying a general purpose interrupter algorithm like you're doing. My analog DRSSTC interrupter works fine for me, and it took me less time and effort to design and build than a digital one would have, but I'm happy to help any folks who want to make a digital one.
BTW, for isolation, I did in fact use a TC4422 driving a 50 ohm coax, which drove a pulse transformer at the Tesla coil end.
I used a bare board, but double-sided PTH. I found that the MCLR\ line had to be jumpered solidly to 5V, or the PIC would reset itself mid-burst from time to time. Even with the pull-up resistor, it still picked up enough EMI to reset.
