  • Guests: 22
GODSFUSION (37)
Zajcek (37)
ElectroDog (33)
sportcoupe (56)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
04/29 ElectroDog (33)
first light for a NST powered 3.5" TC
sparky
Sat Mar 03 2007, 09:25PM Print
This was tesla coil that was designed for a Fine Arts show.
specs: 3" X 29" tall, 27AWG wound secondary
9 turns 3/8" Copper tubing primary
31 nF 45kV rated MMC bank
12 kV 120mA NST, 1.440 kVA
static gap - tug-zirconium electrodes
---look for the video on my next post on this thread.
Michael W.
Sat Mar 03 2007, 09:35PM
Michael W. Registered Member #50 Joined: Thu Feb 09 2006, 04:07AM
add the video.....? confused
sparky
Sat Mar 03 2007, 09:45PM
here is the video:: MPEG 4
]1172958324_530_FT21549_dscn0423.mpg[/file]
image from movie file: cheesey
1172960370 530 FT21549 Movieclipping1
Windows Media Video - no sound. Sorry guys... cry
]1172966834_530_FT21549_dscn0423.wmv[/file]
Sun Mar 04 2007, 12:09AM
You did read the "no double posting" rule, right? I combined your multiple posts, in future please go figure out how to attach multiple files to a single post. Anyway, the coil looks pretty good! smile
sparky
Sun Mar 04 2007, 01:22AM
alright... how come I can't delete my own posts or remove uploaded content? curious...
Anyways, the output of the coil should be 50" ... 12kV 120mA ??? what do you think?
Sun Mar 04 2007, 03:03AM
you can't delete posts becuase it confuses people, to remove uploaded content you go edit your posts to remove the links, and then go here and click the delete button.
As to the output length, for a beginner coil you can't really expect full spark length... But you should get decently close to it...
sparky
Sun Mar 04 2007, 07:47AM
thanks for the info... will keep this in mind for sure.
I only have 8 turns on my primary coil - and I'm thinking if I add a few more turns I might get better output? What do you think?
Sun Mar 04 2007, 08:11AM
You need to tune the number of turns to match the primary cap you are using. Try using 7.5 primary turns, and see if it shortensthe output. If i does, then add more turns.
sparky
Mon Mar 05 2007, 02:19AM
I put several more turns on the primary and increased the size of the toroid... and the spark length increase by 15" ---- WOW impressive!!
