  • Guests: 17
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Too big capacitor?
Mark
Thu Mar 01 2007, 10:44AM Print
Mark Registered Member #558 Joined: Thu Mar 01 2007, 10:28AM
Is it possible to have decent spark using 32nF/16 kV capacitor with NST (12kV 20mA)...? Currently the spark is just few inches, maybe the coil is not tuned correctly. But before I start to put more effort on it, I would like to ask if it's even worth trying or schould I try to find smaller cap. According to my calculations optimal cap is 6.6nF so the one I got is far too big.
Cheers,
Mark
Thu Mar 01 2007, 03:51PM
Getting the right cap size is important, as it affects the resonant frequency of the primary. If you calculated 6.6nf, but are using 32nf, switching to a smaller capacitor should help. Make 8 beer bottle capacitors, and you should be close to 6.6nf.
J. Aaron Holmes
Thu Mar 01 2007, 04:16PM
Too big a cap is a no-good thing. I'm thinking you probably want something around 8nF to be LTR for a 12/20 NST. So you're about 4x where you want to be!
A way-too-big cap probably means your NST can't charge it to full voltage fast enough. Your firing voltage will be reduced, requiring your gap to be tightened, and exponentially reducing performance. At the same time, to bring your coil into tune, you'll have to have far fewer turns on your primary, which together with the larger cap value, means your peak primary current will be much, much larger. So add higher I*I*R losses to the fact that a tigher gap with higher current is also generally harder to quench properly, and you can see why getting the cap value right is so important!
Regards,
Aaron, N7OE
Hazmatt_(The Underdog)
Thu Mar 01 2007, 07:24PM
You definately want the capacitor to be the right value. Too small and the voltage soars too high, too large and your shorting out your transformer too much.
Here's a lot more: Link2
Mark
Thu Mar 01 2007, 07:42PM
Thanks, that was exactily what I suspected I just needed a confirmation from experts. So in case of too big capacitor the NST don't have enough time to cherge fully, if I have understood correctly.
Cheers,
Marko
Mark
Sat Mar 10 2007, 08:47PM
uzzors wrote ...
Bottle caps I made were a great success! Thanks for this hint. Now my teslacoil is able to make now sparks about 20 inch long. I guess that I can't make much longer sparks with 300W NST (12000V, 25ma)
Mon Mar 12 2007, 08:43PM
Glad to hear you got it tweaked! cheesey
