Registered Member #33
I have acquired some 16kV 20nF metallized polyester caps. I have not been able to find any data on them, but similar caps from the same manufacturer (ASC) have a peak current rating of only around 10A. Are these caps OK for marx duty, or do they most likely have too high ESR/ESL?
Registered Member #72
It depends what you want to use your marx for.
If you are using it to create transients with a known source impedance and reproducible shape for testing commercial HV transmission components, then you would have to control the series connection of all the ESL/ESRs to be substantially less than your target source impedance. It's quite interesting to read the technical specs and background of such marx generators, their shaping networks, some even build capacitors out of lengths of 50ohm cable to get a known duration discharge and accurate output impedance.
However, if you want sparks, especially spark length, it matters not a jot.
Registered Member #146
With only a 10A rating, you might need a series resistor, making the output sparks less than exciting. I really find the 10A rating puzzling though... its really small.
What would happen without the series resistors?
Here is a datasheet for some different caps from the same manufacturer, those were the only 16kV types that I found the datasheet for. This is where I got the peak current figure.
