  • Guests: 26
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
NST grounding
Tue Feb 06 2007, 10:40PM Print
I apologize for asking this again, but I don't know if anyone notice this question which I posted several days ago. The ground on a NST is the mid-point of the secondary. If I have a Terry Filter where the HV terminals connect to two doorknob capacitors and a static gap. The mid-point of each is grounded. Do I still need to ground the NST?
Tue Feb 06 2007, 10:52PM
You'll get as many different answers on grounding as there are Tesla coil builders, and most of them work fine. Personally, I would tie the NST winding midpoint, NST case, and midpoint of the Terry filter, all to green wire ground. This should give maximum NST protection at the expense of possibly sending crud back into the line. But IMHO YMMV etc.
Hazmatt_(The Underdog)
Wed Feb 07 2007, 02:42AM
And I was saying that Case ground and Midpoint ground are not the same thing on a GFCI NST. So you have to be careful which one you choose.
>>> Here's some more: Link2
Terry Fritz
Wed Feb 07 2007, 07:34AM
Hi,
Gary Lau has a lot of info here:
I ground everything to a ground rod. I don't even carry the AC ground near the coil.
I am not sure any two people have the grounds connected the same way though cheesey
Not sure about a GFI NST. I would ground everything that "can" be grounded...
Cheers,
Terry
Wed Feb 07 2007, 10:54AM
Well, in the case of a GFCI NST I'd also disable the GFCI module and connect the winding midpoint to the case. The disadvantage of Terry's method is that the incoming hot and neutral wires are referenced to green wire ground, but everything else is referenced to RF ground. So if your RF ground is bad, the NST may arc over between its primary and its core.
Lately I have been apartment coiling with everything, includig the secondary base and strike rails, connected to the green wire ground suprised
