  • Guests: 20
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
HV inductor
attune
Tue Dec 26 2006, 05:14PM Print
attune Registered Member #259 Joined: Sun Feb 26 2006, 05:57PM
I have recently built a 1000W DC-resonance coil, powered by a voltage-multiplied MOT. The design requires an inductor around 30H, and I have been using two MOTs with the secondaries connected in series, with the 'I's cut off. This works fine, but I am worried about insulation failure. Also, they are quite heavy. I would like to make my own inductor, and have a few ideas.
>Thicker wire, like 24 or 22, to allow for higher current and longer use.
>Layers insulated with HDPE
I have a problem, though. None of the cores I have are suitable for the project. I have searched online for a large ferrite C core, but cannot find any supplier. Does anyone know of any site that sells them? Thanks.
Wed Dec 27 2006, 01:09PM
You are talking about the charging reactor, I suppose.
With a toroid core, you will face even more severe insulation problems than with an ordinary E-I or U-I core. And a powdered core will not supply the inductance you need.
I understand that you want lower weight, but this is only possible to a certain point.
Since you are able to run with the MOT`s, I`d say you already have suitable cores. Removing the primary winding will accommodate thicker wire and or more insulation.
Could you publish more detail about your design?
Cheers, Finn Hammer
attune
Thu Dec 28 2006, 05:27PM
Ah, I mean a 'U' core, not a 'C.' The design is very similar to Steve Conner's Tesla 2. http://www.teslaboys.com/Tesla05/T05Power/index.html is a coil with a homemade charging reactor using a U 100 core, but I cannot find this product anywhere...
Thu Dec 28 2006, 06:46PM
Laminated iron is probably better than ferrite for low-frequency applications like this. Not to mention cheaper and easier to get. I've managed to salvage a few pairs of laminated iron C-cores from old transformers.
If you use thicker wire, then the core will end up being bigger and heavier to give the same inductance, because it needs a larger winding window. If you want a more compact inductor, start with thinner wire.
Good to see my old Tesla-2 design is still doing its thing smile
