  • Guests: 32
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
Coil to Spark Length Ratio
Coronafix
Wed Dec 20 2006, 12:12PM Print
Just wondering what the best spark length to coil length ratio people are getting.
My little coil has been pushed to approx. 15" sparks (to ground point) out of its
8 1/2" length. I reckon that is pretty good, but I know that the DRSSTCs get
better than that. So any way, just approximately, my ratio is 1.7.
I know that it all depends on power input, but really, how far can you push a little coil???
Wed Dec 20 2006, 12:32PM
As far as I know, I have the record for this, with 5ft from a roughly 13" tall secondary (a ratio of about 4.4)
Coronafix
Wed Dec 20 2006, 12:38PM
Wow, that's hardcore! amazed A lot more than I expected!
Marko
Wed Dec 20 2006, 02:00PM
Haha. Steve definitely pwns noobs in this part. tongue
It's all about putting a small secondary on oversized bridge and trying to get sparks as much as possible away from the coil.
I don't know if that counts, but Steve Ward got 5,14 resonator lengths (21inch coil, 9 foot spark) with his large magnifier setup; biggest ratio I know yet. Link2 (Maybe a driver should be in count also?) Dan McCauley also got something 4-5 secondary lengths IIRC, with small coil, but at that point his secondaries started blowing up.
From all that, it seems that it's pretty plausible to get ~5 resonator lengths, if spark is moved (by any means) away from hitting the driver itself.
Hazmatt_(The Underdog)
Wed Dec 20 2006, 08:42PM
Spark length I don't really think is a good metric because there is more to a system that gives you that spark length.
I'm getting about 40-48" out of my 24" coil, so its roughly 2:1, but that's not nearly enough information. What is to stop me from using my PT and doubling that length, nothing. This is why I don't use this kind of measurement. I use length/Joule. My factor for length/Joule is approximately 3 feet/Joule of bang energy. This eliminates all other factors. It doesn't care wether you use a PT, NST, MOT, FBT, because it is the core element of the tank.
This also stresses another point, an efficiently matched tank/supply. I've got my simulation and numbers now that I know what the best match really is and its not pi/2*Cresonant (That only gives you a 90% match). My point is that I can drive a little over a joule with an NST efficiently. I'd like to see more people get their systems calculated right, use only the needed amount of power, and get their spark length based on 3'/Joule.
Wed Dec 20 2006, 10:02PM
I don't see how length per joule is a good metric either, since most people believe that the spark length from a Tesla coil is proportional to the square root of the power input, so there's a good case for arguing that it's proportional to the square root of the bang energy too. It should be length per root joule or something.
Did you measure the power input to your coil for a 48" spark? What is it? The record for "Freau Factor" is about 1.7 (inches per root watt) so if you beat that, we're impressed. Me especially because I've never managed it :( There's a whole load of discussion on these various metrics in the Pupman archives since the year 0.
P.S. I tried to coin the name "Watts Number" for (spark length/coil length) but it never caught on the same as "Freau Factor". My current thinking is that you can't have both high at once: if you design for a high Watts number you get a low Freau number and vice versa. John Freau's original coil that set the 1.7 benchmark only had a Watts number of about 1.5 IIRC.
Tesladownunder
Wed Dec 20 2006, 11:49PM
For a SGTC my 6 inch coil Watt number is 3.0 with a clear photo showing this. (32 inch sec, 96 inch spark) I have not seen better than this with photographic proof. Clearly the DRSSTC's do better. Magnifiers need to take into account the height of the secondary as well as the tertiary coil and then become just ordinary in performance.
I was thinking the other day that I now have the tank cap and power gear to get a lot better performance out of that coil as it was very well behaved and didn't have any racing sparks or obvious impending failures. It is not just a case of doubling power giving better performance of course - something will "break". The big double toroid and high break rate of 1100 BPS were probably the key features in the performance.
Peter
1166658539 10 FT19055 Tesla 8ft1
Thu Dec 21 2006, 01:16AM
Most of my high performance coils get around 3-3.3X the winding length. The harder you push on them, the less efficient they seem to become at making long sparks.
I dont count my magnifiers unless you want to add secondary and tertiary length. In which case i think that was 22" + 17" for 39" winding length for 108" streamers which is only 2.76X or so.
Hazmatt, the only idea here is to see what spark length a secondary can support. It says nothing about the efficiency of the setup. I personally think its a pretty cool measurement, because it relates the output performance vs size.
Thu Dec 21 2006, 01:36AM
That's fine that you guys want some kind of overall performance factor, I don't have a problem with that except that I believe its a bit misleading and not really representative of the system.
I have been taking note of the Joule energy of coils and 3'/Joule is pretty reliable. I met a coilier at a swapmeet who is an engineer, using a large pulse discharge capacitor and repition rate of 3s/bang. His 12' spark length and 4 Joule input confirm what im finding. So wether others believe it or not doesn't really matter to me, since my findings are holding true. All I'm trying to suggest to all is that this is a more realistic approach to characterizing spark length, at least for a SGTC. If you don't or don't want to believe me, that's fine, but I would suggest you test the theory first.
I can't give you exact figures for Wattage because that transformer is dead now. I do have a clamp-on that will give me what you're looking for, but the coil is at college right now getting 'prettied' up. My input NST was a 12/60, the capacitor was I think 16nF, but it could've been 18nF. It's hard to remember because it was a while back. What I have been working on is the real system simulations rather then the model. The real system uses a 9kv/120, and the model was a 12/60 as I've already stated. So basically I've been doing more preparatory work for the finished system, and its spark length should be 6.3' from my Joule calculation.
teravolt
Thu Dec 21 2006, 04:37AM
when drssts are operating why do sparks have a tendancy to reach out ? is this a phenomina of drsstc's ?
