  • Guests: 28
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
IR DVD Laser Project (Videos)
Madgyver
Sat Nov 25 2006, 06:54PM Print
I recently took apart an DVD recorder and was able to run the IR Diode with a LM317 constant current source. The beam of the Diode has of course very big angle, so I had to collimate it with optics from a cheap Laser Pointer.
Driving it with 150mA of current makes the beam strong enough to burn and cut stuff.
Enjoy the videos:
Any Comments or suggestions?
Wilson
Sun Nov 26 2006, 08:00AM
Wilson Registered Member #78 Joined: Thu Feb 09 2006, 11:27AM
Are you using the laser diode for CD burning? or dvd burning?
ragnar
Sun Nov 26 2006, 08:26AM
Hahaha, pun not intended? =P
Madgyver
Sun Nov 26 2006, 12:03PM
Its the Laser for CD Burning, which ist IR. The one fpr DVDs is bright red. I accidenly broke that one, the output window broke.
Marko
Sun Nov 26 2006, 12:11PM
Cool stuff, I tought it would be much weaker than that.
Now all you have to do is to gather some more dead writers and build a burning LD array from hell :)
How far can beam be focused with that laser pointer lens?
Have a diode number or datasheet visible? (in case there's room for some more current to be pushed :)
Madgyver
Sun Nov 26 2006, 12:18PM
Well theoreticaly focusing infinity is possible, but practically I lack the proper tools at the moment and basically time to bild something decent. 100m shouldn't be impossible though.
The Diodes often don't have a number and tuning is often not possble without destroying the LD by accident.
Wilson
Mon Dec 25 2006, 05:22AM
Is it possible to use the pre-exisiting collimator and lense system from the DVD player instead of substituting it with another one? Seems like that would be easiest if possible, albiet with some power loss.
Electroholic
Mon Dec 25 2006, 06:20AM
optics in the drive are suppose to focus the beam to a tiny dot just a mm or two above the optical head, and is very divergent. not that useful if you ask me.
Mon Dec 25 2006, 08:34AM
If I am not mistaken, the beam is focused down to a small spot only at the end of its journey withing the optical assembly. It wouldn't surprise me that if you removed the last lense, you would get a nice colminated beam coming out. If you wanted to cut the size down you could probably just take the first lense after the didoe, I would assume that it is the one that does the colminating.
Have fun!
Mike
Mon Dec 25 2006, 09:02AM
haha cool stuff, I believe I saw something very simmilar to this on Hackaday.com , I was gonna try it but didnt have any unused dvd/cd players around.
