Registered Member #192
Hello,
I was surfing the net for UV leds and found something very interesting. Opto Technologies has these SHARK high power emitters, some in the UV range and other are IR. They look like a transistor but actually have 50 leds in them. It works out to 1/4 watt of UV energy output. The IR units could be used for IR illumination. I thought you should see them, but what applications could we have for them.
Registered Member #56
I can only think of 2 things... Checking for glow-in-the-dark rocks, or curing UV epoxy.
I doubt that you will get enough energy to do much UV curing (my incandescent gun is like 50w), and for finding rocks a small handheld 7w tube would be a lot cheaper.
Registered Member #103
I've been thinking, but I can't really come up with anything... I guess the UV is a bit too concentrated for exposing PCBs.
However something like that is ideal for sending data, or audiomodulating. It's easy to mount and a good size for having a lens mounted in front of it, you could probably get across a valley with it, except IR is usually used anyway. I'm not sure what you'd use on the recieving end for a UV link (or if it would even work due to the atmosphere).
Now if one of those were available in IR, I would be very interested indeed!
Registered Member #89
You can use IR laser from DVD-writer as a powerful and fast transmitting source.
UV LED's simply aren't designed for such application.
To un-concetrate the light you can simply move the source away from PCB; anyway, there is actually little use for such a thing while looking on it's price.
Registered Member #311
... wrote ...
But your gun probably puts out a tiny fraction of this wattage as UV. LEDs are a lot more efficient. UV Curing of things like dental adhesives is one common application.
Banned on April 8th, 2007. Registered Member #597
Heh. I bet they *won't* send me free samples.
Hmmm. If it's bright enough to cure the entire surface of a pool of plastic monomer, maybe it could be used for stereolithography "3D printer" rather than a UV laser. Put an LCD over the liquid pool to cast programmable shadows.
Also, I think 365nM is getting into the nasty range. Kill bacteria, cornea damage, etc. The UV LEDs from DigiKey etc. are more like 395nM, barely UV at all.
Registered Member #799
Hello, Powerfull UV LED's may be also used for air and water purification ( Killing germs and bacteria) and also generating ozone. If a power UV LED is placed inside an integarting sphere , it will be a powerful tool to cleanse the air inside the sphere.
