Tektronix p5205 differential probe
Sun Sept 13 2020, 01:34AM
Registered Member #190
Does anyone know how to open the case on these without destroying it? I don't see a screw holding it together and I don't want to put too much pressure to pry open the case in case there is one.
Flyglas
Sun Sept 13 2020, 07:38PM
Registered Member #62305
Maybe these pictures will help you:
Mon Sept 14 2020, 11:05PM
thanks. I saw those pictures prior but I could not find the screws on the back under the label. I finally decided to peel the top plate and they were there.
Thanks for the reply.
