  • Guests: 32
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Good explanation about how railguns work....
Slava
Mon Aug 17 2020, 05:51PM Print
Slava Registered Member #518 Joined: Tue Feb 13 2007, 05:20AM
Instead of using Lorenz force to explain railgun operation... I found a more elegant way... Using flux compression force.... Basically a wire with current going through it doesn't want to be bent and tries to become a straight line... The junction between projectile armature and rails forms a 90 degree angle conductor which tries to straighten itself out, causing the armature to accelerate outward.
