rail capacitors for noise
Fri Dec 13 2019, 06:39PM
Registered Member #190
I have a 330uf capacitor on a switching chip on the V+ pin so it has enough amperage to drive the gate of a switch. Would I still need to add a 0.1uf capacitor for noise spikes, or is the 330uf capacitor sufficient to handle both situations?
2Spoons
Registered Member #2939
Generally yes, you should add the 100nF cap. Check the impedance vs frequency spec for your caps, so you cover the areas needed
