Is it possible to use a ULN2003 darlington array to drive a mosfet gate
Fri May 10 2019, 05:20PM
Registered Member #2431
Is it possible to use a ULN2003 darlington array to drive a mosfet gate ?
it seems like a good way to drive 7 tiny mosfet gates that dont need a huge "thunk" of drive that or big HV mosfets and IGBTs gates need. im trying to use some logic pins to control 6 or more transistors.
As many of you know im always resisting the use of digital logic IC's in direct HV use, but in this up coming project its unavoidable.
I just dont want to buy a bunch of gate drivers if the ULN2003 can do this and other things.
Registered Member #162
I have seen ULN drivers used to drive FETs in many types of industrial equipment. From memory, the most important parameters; . Vce ON voltage ... must be low enough to ensure that the driven FET is turned off . Speed ... usually 10's or 100's kHz. 1 MHz is (generally) too fast
If switching is not too fast then almost any FET or IGBT etc. can be driven by ULN drivers.
ok ill buy some then and report back.
