Registered Member #2099
No. Not that I've potted any windings myself, or watched it done. Vacuuming the mixing pot can get rid of most tiny bubbles. Vacuuming the potting pot won't affect resin viscosity, surface tension, or wire-wetting properties. It can prevent tiny bubbles from forming as resin soaks into the windings, if resin is poured in a vacuum.
Best way to reduce the viscosity is to heat the resin, and deal with the reduction in working time.
Why is important for resin to penetrate coils of fine wire, except to improve tolerance to vibration?
Registered Member #162
I think that the viscosity would not change, but the lack of air may prevent the forming of a skin on the potting compound as it penetrates voids, stopping due to surface tension.
I'd probably give the coil a few dips in polyurethane varnish or similar, with drying after each dip. Clean up excess polyurethane then pot the assembly as required.
Registered Member #103
'Vacuum impregnation' is certainly a thing in the industry, I've seen it done with electric motor stators but with much thicker wire. For fine wire I guess you'd need to use some type of varnish with a viscosity more like water.
Registered Member #11591
I have had a lot of good experience with this for waterproofing electronics. The breakdown voltage isn't too bad either, and the viscosity is on par with water, and the lowest I could find for an OK price, it's pretty cheap and easy to find. It has a nice hard-rubber consistency after curing, but will crumble if heated with a hot-air gun.
