  • Guests: 30
Adam Munich (30)
Alfredo Texacca (60)
05/02 Adam Munich (30)
05/02 Alfredo Texacca (60)
05/04 Matthew T. (35)
how to interupt sstc
KUN
Thu Apr 18 2019, 12:54AM Print
KUN Registered Member #61824 Joined: Mon Oct 02 2017, 05:38PM
Hi, i am currently messing around trying to build interupted SSTC. I have build simple SSTC using only 1 mosfet, resistor, cap, and 1 potentiomiter. It is very simple but works well. I now want to interrupt it. I made ne 555 timer circuit, i can change freq with potentiometer it works on led light but now my question is how do i use it with my coil. I was thinking about just connecting output of 555 chip to the base of some npn transistor. I would then connect positive of power suply to collector and coil drivers + input to emitter. I assume the problem would also be that i am using 2 separate power supplies 1 to power interrupter and one for the coil. So, how do i make 555 circuilt switch transistor that switches my other power supply for coil on and off. I tried the whole thing with led, and it only lights up and works if i also connect negative of timer circuit to the negative of led and negative of other power supply. What is the reason i am not able to do that the way im trying and how to work around this?
KUN
Tue May 07 2019, 10:41AM
Anyone?
Fumeaux
Thu May 09 2019, 10:30AM
Fumeaux Registered Member #61890 Joined: Sun Nov 05 2017, 05:57PM
do you have an schematic?
