  • Guests: 29
Adam Munich (30)
Alfredo Texacca (60)
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
A question about VTTC
hyparh
Sun Mar 24 2019, 01:08PM
hyparh Registered Member #1054 Joined: Wed Oct 10 2007, 10:51PM
Thanks for the analysis! Yep, I have one 5KVA variac - very handy for different experiments.
I think I found a very good solution for the cooling (price, dimensions etc.): Link2
"Air Volume: 190.30CFM"
PS. That's one neat VTTC you've got there! :) (though it gives me an error when I try to open the images)
Sun Mar 24 2019, 01:49PM
Just be aware that the fan that you pointed to is 4-wire ... external motor drive/controller required. (cheap via eBay)
Fans of this type are reliable Link2 and designed for various ready made ducting options.
An axial fan should suffice, bigger = less noisy, e.g.120mm should be ok.
From memory: MOTs become more efficient at 10% to 20% reduced operating voltage.
MRMILSTAR
Sun Mar 24 2019, 03:43PM
MRMILSTAR Registered Member #62119 Joined: Sun Feb 04 2018, 04:59AM
The image feature has been broken for a while on 4hv.org. Hopefully it will soon be fixed.
hyparh
Sun Mar 24 2019, 10:02PM
Sulaiman wrote ...
Isn't it like a PC fan? I mean, no matter how many wires they have, as soon as you figure out the two "main" ones, you can run it at full speed? I did this with many PC fans.
The Lightning Stalker
Mon Mar 25 2019, 12:17AM
The Lightning Stalker Registered Member #4230 Joined: Sat Nov 26 2011, 05:50AM
Some microwave ovens have instead a centrifugal blower that flows more air than a standard rotary.
