  • Guests: 44
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Chinese Small 15kV Transformers and the Oscillograms that will Follow.
Thu Jan 31 2019, 12:11AM Print
here are the imgur pics of the newest transformers in my arsenal.
Thu Jan 31 2019, 01:17AM
Thu Jan 31 2019, 02:26AM
it has a 0.005" gap in two places not really happy about that.
Thu Jan 31 2019, 02:31AM
my edit button doesnt work, so bear with me:
the ebay links : Link2
ritaismyconscience
Thu Jan 31 2019, 06:26AM
ritaismyconscience Registered Member #62937 Joined: Wed Jun 06 2018, 08:20PM
Might want to put it in epoxy
Thu Jan 31 2019, 07:06AM
Last year in May I bought one of these Link2
a fun little module.
I gave the secondary a dip in polyurethane varnish, I don't know if it helped.
The airgaps are easily adjustable by using different thicknesses of shims (paper, plastic etc.)
As supplied the kit makes 5mm arcs easily but gets too hot for my liking within about 10 seconds of continuous use.
For longer run time decrease the thickness of the shims/airgaps.
(this kit uses a one transistor blocking oscillator so core heating is roughly proportional to frequency and smaller airgaps give lower frequencies)
The primary was easy to unwind and re-wind with a primary of my choice.
I think that this is an excellent bit of kit for anyone starting in high voltage experimentation.
Thu Jan 31 2019, 04:25PM
yes i considered that module too. its the same transformer. do you mean the transformer or the transistor get to hot ?
i was thinking of removing the shims entirely, making it a normal transformer. then vacuum pulling a epoxy or other material.
a single part urethane for wood is interesting but a bet it would start to volatilize when i apply vacuum.
Thu Jan 31 2019, 06:24PM
primary = 25 turns @ 0.015" , 26 awg.
feedback (or reset ?) = 35 turns @ 0.008", 32 awg.
circle side area is 0.057 inches. (0.27 diam)
im wanting to recalculate a primary for 1500 guass. but i got to go to work. i had all this figured out for my planar and UU cores, but need to look at my notes and maybe find the threads here on the forum.
Sat Feb 02 2019, 08:23PM
ok im attempting to rewind them as a "flyback" type (conventional topology, not TV kind) with a diode+reset winding and no core gap. im not sure waht the volt/amps are for 1500 guass given the above info.
hen918
Sat Feb 02 2019, 10:13PM
Reset winding? You need one of those for a forward converter, not a flyback
