Soft Encapsulants.
Registered Member #2431
this "Xtreme UV", is it the kind of UV light curing type?
I worry about curing normal hard epoxy due to heating and cooling causing failure (cracking) later in life. If I'm going to the trouble of vacuum potting I want these to last.
I'm theorizing a method where we depart from the traditional flyback solid block and move to an oil/epoxy hybrid. this would mean a thin (.050) cured epoxy layer - vacuum potted to the bobbin and windings. then a small tank of oil to do the bulk insulation. But liquid tight containers that don't burst or leak are not ideal.
Registered Member #96
It is! I've also used it for LED repairs and it works well.
