  • Guests: 23
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Vacuum Triodes
Chris Cristini
Sun Jan 20 2019, 07:48PM Print
If we could make Triodes with today's manufacturing techniques would they be worth anything other than Vttc?
hen918
Sun Jan 20 2019, 10:11PM
I'm not sure about triodes specifically, but vacuum tubes/valves are still used in large high power radio transmitters. For dealing with a few hundred kW in the MHz, they work pretty well.
2Spoons
Mon Jan 21 2019, 07:46PM
There's a lot of love for vacuum tubes in the audio world.
the_anomaly
Mon Jan 21 2019, 11:17PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
What improvements would today's manufacturing techniques bring? Tube performance? Longevity? Cost to Manufacture? I second the audio group as a strong interest.
Wed Jan 23 2019, 11:57PM
The Russians continued producing new thermionic valve designs long after development had all but stopped in the West, which lead to the production of some excellent miniature and sub-miniature valves.
Thermionic valves are much more tolerant of EMP and radiation than semiconductors, and some Russian miniature valve data I have seen includes high G force operation, suggesting their use in missiles, but I am only speculating.
You can make yourself an excellent little triode super-regenerative radio receiver, with a sensitivity of a few microvolts, great fun and sensitive enough to pull in a good range of short wave and VHF signals.
Chris Cristini
Thu Jan 24 2019, 03:33PM
I was just thinking Tubes are much easier to develop something new/improve VS semicondors.
I mean just the simplicity is awesome maybe even try a different approach to Electron flow vs Heating elements. Maybe laser to heat a thin Metal plate at 2W vs 40ish? It could be like the IGBT where you have the robustness of a transistor and the ease of driving like a Mosfet.
Chris Cristini
Sat Jan 26 2019, 04:41AM
Sorry that was a tired post didn't make to much sense my question is basically can there be efficiency improvements? I did a bunch on research and its not promising. :)
radiotech
Sat Jan 26 2019, 08:46AM
Vacuum tube development in the past advanced as a result of specific needs
that arose. For different and more efficient processes for manufacture, first describe
a need, and it will be met.
As to lasers heating thermionic cathodes, some vacuum tubes do not need heaters.
Their cathodes develop a space cloud when an ionized gas pulls electrons off and heats it.
An example is the 0Z4 tube, and 'instant start' fluorescent lamps.
Sat Jan 26 2019, 03:24PM
Wonder if it's possible to make a vacuum tube single chip computer? Using nano thermonics
Sun Jan 27 2019, 02:12PM
The Nuvistor series of triodes and tetrodes introduced by RCA in 1959 were metal and ceramic thermionic valves smaller than a thimble. They are excellent low noise performers (by valve standards) and the very small interelectrode spacing makes them good performers up into the UHF.
