Need help with coilgun barrel
ritaismyconscience
Sat Nov 10 2018, 05:38AM
Registered Member #62937
Hi, I got 6 16000uF 350V capacitors for a very low price on Ebay. I finished the charging circuit (ZVS), and it works. How should I create the barrel and how many turns should I use?
Registered Member #162
You can start here
V2006
Registered Member #61550
To wind a coil, you will need a copper wire with a cross section of more than 10-12 mm 2 (for example, 3x4 mm), but you can wind a round wire with a diameter of 2.5-2.6 mm if two wires
