  • Guests: 14
Alfons (36)
Coronafix (51)
AmonRa (44)
05/09 Alfons (36)
05/09 Coronafix (51)
05/09 AmonRa (44)
Electronics goodie box competition
Fri Sept 07 2018, 08:01PM Print
Hi all.
(Mission Impossible voice)
"Your challenge should you choose to accept it, is before 12 midnight on Friday 14th September design build and test a circuit which is able to reliably detect a signal between 25 and 27 MHz and display an indication. The test circuit it must sense is an unshielded micro (3.3V) oscillator as used on many cheap Bluetooth dongles, Wi-Fi cards and other devices at a preset distance of 10.0 metres. The antenna, circuit and other parts must cost less than £10 UK or equivalent, ideally also be portable enough to fit into a sensible case."
Prize 1 for best working tested circuit: box containing Pi Zero W with NoIR camera and "other goodies".
Prize 2, for "most novel circuit" a slightly smaller box.
EDIT: Extended to whenever *any* circuit is submitted.
-Andre
