Registered Member #162
I do not recognise the part numbers and it may be very difficult to find datasheets because at that time* it was common for larger product manufacturers have semiconductors custom labelled, mainly to prevent third parties from repairing or copying electronic designs.
* date code 7935 = week 35, 1979 (1974 was a very confusing year for TTL IC identification)
The actual transistors will rarely be custom design, just common transistors re-labeled.
Registered Member #2431
does it matter ? I.E. are you fixing original equipment ? can you figure out the functional requirements from the circuit, then identify current transistors that will work ?
figuring out the transistor specs via part marking is the most difficult way for old stuff as previously stated.
Registered Member #62937
I bought a box of parts from ebay and these came with the box. I have no idea what they were used in. It is impossible for me to find out the specs any other way. The parts seem to be from RCA. I think I found the 3801 one too:
I have never even seen a berylium oxide TO-3 insulator - they were very rare, (although I have seen a few transistors that have BeO internally - usually r.f. power devices) Mica was the only common insulator of those times. (with a razor blade or sharp knife edge you can split mica into thinner sheets) ---------------------------- I doubt that the datasheet that you found is for your 380-2 transistor, as we did not have such good transistors back then ;) and NTE did not exist until 1989 ! ---------- I'd expect equivalents to 2N3055, 2N3773, 2N2955 and HOT/flyback transistors from TVs etc. The smaller TO-66 transistor may be 2N3054. I did not do TV repairs so no numbers come to mind, so you will need to do a little research. There could even be a 78xx type regulator in that lot. -------------------- So, as mentioned above, it is best not to use these transistors for a new design, or even an old design - as the transistors are very old. If you are building something new then use newer design/better transistors. If it is just for knowledge/experience/experimenting then go ahead, but do not expect too much performance from those transistors.
Registered Member #2463
The warning about the BeO insulator is part of an instruction manual for equipment I currently own and use. Here is an E-Bay listing for the ultrasonic cleaner I have.
For $120 US you can buy it today.
For $19 US, digikey will sell you a new BeO TO-3 size insulator.
Well that is interesting, I have several TO3 insulators that I've always just called 'ceramic' It seems I may have BeO ceramic ... D'oh ! So it seems that possibly berylium causes memory and hair loss - or is that just age :)
