  • Guests: 16
Colin 99 (53)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Pulse discharge capacitor information sought
MRMILSTAR
Thu Jun 14 2018, 07:05PM Print
MRMILSTAR Registered Member #62119 Joined: Sun Feb 04 2018, 04:59AM
I have 2 large pulse capacitors for which I am seeking full specifications. Here is what I know from the nameplate information.
Capacitor #1:
Manufacturer: Aerovox
Type Number: PM223YW099D01
Capacitance: 102 uF
Maximum Voltage: 22 KV
Capacitor #2:
Manufacturer: Maxwell
Catalog Number: 33504
Capacitance: 106 uF
Maximum Voltage: 10 KV
The additional information I am seeking is the following:
* Lifetime (maximum number of shots)
* Maximum allowable voltage reversal
* Anything else that I can find out
I am going to use the Aerovox unit for a quarter shrinker. I may use the Maxwell for a ring launcher or ???.
Signification
Fri Jun 15 2018, 03:42PM
My first time shrinking quarters was with a few paralleled 4500v @ 32uF...not much luck, you had to put the 'shrunken' quarter against a regular one to know it was even slightly smaller. Then I got a pair of those orange Maxwell pulse caps rated at 12kV @ 70uF each wired in parallel (140uF at 12kV--only charged to <10kV). I have a huge hologram table 4' x 8' filled halfway with sand in which I buried the work-coil containing the quarter. I fired the cap bank, making a mess of shrapnel and razer sharp pieces of 10AWG magnet wire stuck in everything--looked like a grenade exploded, I was wearing VERY good eye and ear protection, so the noise wasn't painful and the thing was buried in sand--completely disintegrated! I dug around, and when I finally saw the coin, I couldn't believe my eyes! Yes, it was a quarter, but so tiny,I couldn't adapt my mind to the familiar quarter + the so unfamiliar size...very weird sensation! It was so hot I couldn't touch it for a short while. After having it for a couple of days, other coins: nickles and penny's appeared to be HUGE--I couldn't get over it? Also, from then on, I wondered why anyone would be interested in squeezing soda cans after this! The size of the shrunken quarter could be controlled by the small variac that simply controlled the final voltage of the cap pair. A large microwave oven diode following the variac output rectified the voltage at the output of a small 7500v NST.
YOU MUST BE SURE TO DISCHARGE THE CAPS BEFORE DIGGING AROUND FOR THE LOST QUARTER!
"KLAATU BARADA NIKTO"
Adrenaline
Fri Jun 15 2018, 04:52PM
Adrenaline Registered Member #235 Joined: Wed Feb 22 2006, 04:59PM
Pictures would help. I believe General Atomics Link2 bought the Maxwell plastic high voltage capacitor line.
