  • Guests: 25
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
Gate Drive Transformer troubleshooting (GDT)
Gordon
Thu Apr 19 2018, 05:10PM Print
Gordon Registered Member #61983 Joined: Fri Dec 08 2017, 12:07AM
Afternoon all,
Ok so i only had time last night to run a test on my SSTC based off Steve's mini coil design using an arduino as the interrupter. I had reconstructed my pcb board trying to make a more neat set up. However when powered up the output was extremely weak. I hooked up my hantek 6022 oscilloscope to the output of the GDT with my main power to the mosfets off and the signal was not square at all it looked almost like a sine wave. Would the GDT cause this or bad wiring around the driver chips? I plan on checking the output wave form of the chips when i get home but of course thought about this while at work and wondered if anyone else experienced this before.
dexter
Thu Apr 19 2018, 06:58PM
do you know what material the GDT is made of?
Gordon
Thu Apr 19 2018, 10:17PM
Here is the data sheet on it
i got it out of a 1800w power inverter
dexter
Fri Apr 20 2018, 07:49AM
Gordon wrote ...
Was that core part of the output filter?
From the datasheet i see that the Al value is to low and the core looses for 200kHz (is this close your reaonant frequency?) is to high for GDT use
Granted i used something similar but with slightly higher Al value om my first coil and got some results but the power was low and the mosfets survived
For all my coils i now use this core: Link2
Paul Benham
Sat Apr 21 2018, 02:36PM
Paul Benham Registered Member #570 Joined: Wed Mar 07 2007, 03:41PM
Hi Gordon,
I think you need much more inductance on your GDT. If changing that does not work try increasing the series coupling capacitor capacitance to the GDT.
Good luck,
Paul.
Gordon
Fri Apr 27 2018, 02:00AM
I've ordered the similar toroid that Steve recommended in his sstc 1 half bridge from goldmine electronics seeming how the part numbers are different but the dimensions are the same hoping that they are of the same material he recommended. I'll update once I can test them. Going to be moving soon finally getting a house and a nice shop to irritate the neighbors and hopefully not my wife with these experiments lol.
Gordon
Fri Apr 27 2018, 02:05AM
Paul you suggesting increasing the number of turns right? I've done a lot of reading but no expert.
dexter
Fri Apr 27 2018, 07:16AM
To inctease inductance you can increase the number of turns the core section and/or the Al value of the core.
But if the core is designed with a diatri uted air gap for filter usage is not suitable for GDT
Paul Benham
Sat Apr 28 2018, 08:39PM
Increasing turns does increase inductance, L=n^2*AL, so double no turns is four times inductance. You really need the correct type of material to not have bad losses and to get the right gate waveforms. If you don't understand the data sheets its best to copy what others have shown to work. Some cores are designed for power transfer(what you want), others for filtering(lossy).
Paul.
Gordon
Tue Jul 17 2018, 05:05PM
Ah got ya, OK so I got the different core with 2200ui
Have not had a chance to run tests been working on my house ugh life priorities haha. What you think about this one, it's the n87. And I want to understand what I'm looking at I think I am finally getting more understanding of it so did I make a good choice for the GDT or could I have made a better choice
