  • Guests: 24
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
IGBT module from 690 V motor inverter (freq drive)
Martin Slinning
Fri Apr 06 2018, 08:58PM Print
Martin Slinning Registered Member #61375 Joined: Sat Dec 17 2016, 05:45PM
Hi.
Can a IGBT module called Infineon FS75R17KE3 be used in DRSSTC? I got this motor inverter i picked appart.. smile
Paul Benham
Sun Apr 08 2018, 12:19PM
Paul Benham Registered Member #570 Joined: Wed Mar 07 2007, 03:41PM
Hi Martin,
I see no reason why not. It does not have a very high current rating, but could be used at a much higher bus voltage with a higher impedance primary.
Good luck,
Paul.
