  • Guests: 21
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
IGBT Installed Upside Down
zzz_julian_zzz
Tue Mar 27 2018, 05:19AM Print
Hi Guys,
Just want to check if you have any insights regarding proper installation of IGBT modules. Specifically on how it is mounted properly on a heatsink. I tried to google but didn't find anything useful regarding this specific subject.
In my coil, I need to install IGBT module upside down (heatsink is on top and IGBT is installed with its terminal facing earth) --- any ideas if it would affect the performance of the IGBT?
I'm thinking that the silicon inside the module would reposition itself over time due to gravity..
What do you think?
Thanks in advance.
Julian
johnf
Tue Mar 27 2018, 08:12AM
use a copper heat spreader then you do not have to worry
Tue Mar 27 2018, 08:27AM
zzz_julian_zzz wrote ...
If the device can not be used up side down then it would be highlighted in the datasheet.
I can't remember ever a power semiconductor device that needed alignment with Earth's gravitational field.
Voltage, current, temperature, humidity, vibration, mechanical stress and time are the common semiconductor killers.
