  • Guests: 11
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Lens to make sun light on a same spot
the_anomaly
Sat Mar 24 2018, 04:27PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
If you get a moderately powerful >300W xenon arc lamp and build a parabolic reflector, you could just shine it at the tree. Probably more expensive and a bit more dangerous due to the tremendous heat generated.
Some arc lamps like this lamp have a reflector built in. The two types used are parabolic and elliptical. You could collimate the elliptical to get the beam you want.
There are a lot of spectrum grow lamps as well that you could look into.
