  • Guests: 21
wpk5008 (34)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
Lens to make sun light on a same spot
AndreiRS
Thu Mar 22 2018, 03:29PM Print
AndreiRS Registered Member #62109 Joined: Sun Jan 28 2018, 10:00PM
Hi. I have been observing some curious stuff in some trees here. The branches which take sun all day, "pop" a lot of new branches. So I was thinking about some shape of lens that would make the sun light hit always a same spot on the tree during almost all day. But then I remembered that concentrating light this way, I will just make the tree light up like a torch. I think I need a lens that gets light from various directions and make it come strait from the other side. But without focusing it too much. Just a little more intense than normal sun light.
the_anomaly
Thu Mar 22 2018, 04:35PM
the_anomaly Registered Member #19 Joined: Thu Feb 02 2006, 03:19PM
Sounds like you would want to collimate light? Two possibilities would be a Fresnel lens or a parabolic reflector..
484e6e 03e0c9c21e654e2fbc00a46984097c0b
AndreiRS
Thu Mar 22 2018, 05:06PM
That is what I need. Well the sun is too far, so I can't use the second option. But I have seen people using fresnel lenses to burn things or to cook food. Maybe if I turn the lens around? I'm not sure if if would work the same way on both sides since I don't have one here to test. Thanks for the help.
Hazmatt_(The Underdog)
Fri Mar 23 2018, 01:48AM
Andre... all you need is some clear plastic like 20 mil thick and a hoop and some kind of stand.
All you do is attach the plastic sheet to the hoop loosely and put it up on a stand. Then you fill the plastic with water and adjust for how much magnification you want, then use a large flat mirror to direct the light.
When you get bored with that, you can use the "lens" to burn stuff, just remember to wear shades or you'll go blind.
AndreiRS
Fri Mar 23 2018, 04:48AM
Hmmmm, I saw that in these survivor programs on TV. I will try to build one. Oh I did some burning already when I was a kid, but never wore the shades. rolleyes
I will make a little one and then I come back here if it works. 5cm or 2 inches in diameter. Thank you.
Fri Mar 23 2018, 10:02AM
Interesting hypothesis.
Some combination of mirrors and Fresnel lenses might work.
Fri Mar 23 2018, 11:26AM
AndreiRS
Sat Mar 24 2018, 12:18AM
Hi Conundrum, I just realised I can't find any of these around here to buy. I will try first with some cheap magnifying glass and also the water lens. If it works I may buy something on the internet.
Thanks Sulaiman, maybe I can put together something like that. I only need to measure some angles, or just get a mirror, go there and try.
Sat Mar 24 2018, 11:10AM
I guess that building a heliostat is a major project in itself.
You could try a static mirror arranged to sweep the bright spot across the foliage as the day progresses.
A large mirror should provide the equivalent of maybe 1 hour extra sunlight per day.
If this is significant then a band of different growth should be seen where the spot travelled each day.
Or just hang a sheet of Al cooking foil behind a test leaf/twig/branch for double sunlight ?
Sat Mar 24 2018, 03:57PM
Maybe a CR servomotor or one beefed up using a larger motor, gearbox (hint: swipe one from an old school stereo with the motorized tuners) and the original trimpot. For this application high speed is not required.
Also relevant, use a simple magnet and 4 pin linear Hall sensor from a defunct VCR or floppy drive motor assembly
