  • Guests: 15
Colin 99 (53)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
class e tesla coil failed (eastern voltage research)
paulj
Wed Mar 21 2018, 07:10PM Print
paulj Registered Member #59353 Joined: Sun Apr 17 2016, 02:08PM
hi,
I've eastern voltage research class e tesla coil, that failed which about 2 hours of activity in total over 6 months.
Both mosfet IXFH16N50P failed for a reason that I do not know, despite a good cooling fan and heatsink.
The tesla coil is well built and produces 3 cm of plasma.
Before starting the repairs I would like to confirm the reason for the breakdown.
I would like to replace the mosfet by something more robust, which works on the same frequency range (4mhz) but which can let more currents pass.
thank you
Paul
DerAlbi
Fri Mar 23 2018, 02:42PM
Go for a SiC Mosfet - search one with matching specs. They will likely be a bit faster..
If a class E fails, it is very possible that the output network is not correct. Have you checked that the output driver has correct ZVS/ZCS switching?
If not, no other mosfet will help... if its a proven design, the failure isnt caused by the proven component.
paulj
Sun Mar 25 2018, 11:57AM
thanks for the advice
Eastern voltage reasearch tells me to reduce the coupling of the coil, which will cause a drop in power.
then they advise against changing the transisor, otherwise the characteristics of the circuit will be changed.
how to measure zvs / zcs, i'm only a simple oscilloscope without high voltage probe?
DerAlbi
Sun Mar 25 2018, 07:20PM
,..buying a high voltage probe wink
I recently completed my set of 4 (now) with P4100.
Its not cheap, but affordable ach worth it given the transistor price.
teravolt
Tue Mar 27 2018, 10:20PM
the mosfet usually switches closes in negative cycle and opens in the positive cycle over the cap. the voltage that develops can be high maybe exceeding the ratings of the mosfet. so does the circuit have a ZVS across the mosfet and is the turn on time correct across the mosfet
paulj
Wed Mar 28 2018, 07:13PM
hello,
I'm waiting to receive the spare MOSFETs, then I'll pass the circuit to the scope.
