Stacked flat secondaries?
Sun Mar 18 2018, 04:18AM
Registered Member #96
Hi all. Has anyone else tried using LP's specifically for this?
Here an obvious flaw is the tendency of the plastic to be somewhat conductive however for certain applications such as wireless power receivers this is less of an issue.
My plan here is to use glass sheets and either plate metal directly onto them or use an ITO panel then selectively etch away areas not needed. For some applications using a shadow mask and graphene will work directly on treated glass, then put under a bromine atmosphere to form the secondary. Simple enough and iodine will work less well.
Also relevant, form silver coils using similar process then seal with Epoxy.
-A
