  • Guests: 10
ramses (16)
Arcstarter (31)
Zak (15)
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Electrometer 10kV
Physikfan
Wed Mar 14 2018, 08:19PM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
The picture shows an electrostatic voltmeter with light pointer for a maximum of 10 kV.
P1760265400x133
My questions to all:
Please, who else has an electrostatic voltmeter in his instrument collection?
Do you have some experience in dealing with voltage measurement by electrometers?
Have you perhaps measured the self-capacitance and the internal resistance of your device?
Hazmatt_(The Underdog)
Thu Mar 15 2018, 02:45AM
I have one, a 30KV unit, but its buried and I have not measured it.
The internal resistance should be tens of mega ohms, if not a hundred mega ohms.
Unfortunately, I broke my 30KVDC spellman high voltage power supply, so I don't really have anything to test with.
If you get a piece of tube test equipment.. its probably better not to try to clean it and break it in the process.. ;p
Flachzange
Fri Mar 16 2018, 06:44PM
Flachzange Registered Member #61569 Joined: Sat Apr 15 2017, 05:12PM
We have several of these but they are not in use any more.
If i remember right, then one was for 30kV (exactly like this one Link2 ), one for 100 kV and one for up to 400kV.
The last one is almost 2.5m high and have electrodes with 1m in diameter.
If you are interested i can make some pictures of these.
The resistance is very high. At least it is in the range of Tera Ohms.
Physikfan
Fri Mar 16 2018, 08:32PM
Hi Flachzange
I would like to see the pictures
of your great voltmeters very much.
Are you with a special institution for
high voltage Research?
Sat Mar 17 2018, 02:42AM
is the "light pointer" shining mechanically or is it polarized by the HV field its measuring ?
Flachzange
Sat Mar 17 2018, 07:56AM
The light point is mechanically deflected by a mirror that is influenced by the electrical field.
Yes, i am in the national metrology institute of germany in the working group for high voltage metrology.
Flachzange
Thu Mar 29 2018, 05:46PM
Here is a electrostatic voltmeter for 30 kV.
1522345754 61569 FT174223 20180320 112039
It is called a Starke Schröder Voltmeter.
Flachzange
Thu Mar 29 2018, 05:51PM
And here is another one for up to 100 kV that is about 1m high.
It is identical to the 30 kV one it only has "some" dust on it.
1522345871 61569 FT174223 20180320 112330
Physikfan
Fri Mar 30 2018, 09:23AM
Hi Flachzange
Both electrometers (Starke & Schröder) are wonderful instruments.
Please, may I ask you
1. What are the experimental errors for each measurement (precision as well as accuracy)
2. What is the procedure to calibrate these instruments
3. What standards do you have available for these high voltages?
Regards
Physikfan
Flachzange
Fri Mar 30 2018, 11:02AM
Hi,
to 1.) i can not say anything, since these were not used within the last 20 years or even longer.
In the box of the first one might be the instructions were the uncertainty is listed. I will look it up and report if i find something.
2.) For the calibration: I would compare these to a reference divider and then check them over the entire voltage range.
3.) Our reference divider for DC is made for 100 kV with an extended (k=2) uncertainty of 2ppm (0,0002%). For up to 300 kV we have to dividers with 10ppm. And within the last two years i have build four dividers each with 400 kV (20 ppm). They can also be combined (stacked on top of each other) to measure voltages up to 1.6 MV.
