Registered Member #61695
Static charge detector. The lights are red for positive charge and green for negative. It is meant to be directional, but the lights can be uneven. Detects charged materials such as clothing, blankets and furniture.
Registered Member #2906
Cool thingy My first reaction was "WTF, how.. ." Floating mosfet gates, i guess? Effectfull. You could even sell it to the strange people that believe in field harmony magic and stuff.
That is a problem. The lights sometimes stay on and I have to dissipate the charge on the gates by touching something grounded and then touching the inputs. I might try to add high value resistors from gate to drain to bleed off the charge.
I have also noticed that when moving away from a charged object, it detects opposite charge. This is noticeable in the video. The pink blanket on the left is positively charged (red), but moving away from it creates a negative charge (green).
Hmmh, what you describe sounds like leakage current is already influencing stuff, so adding resistors will only make the problem worse. Against leakage current, you could try to a) use way bigger antennas, so there is more charge overall thus longer leakage time b) maybe using a reverse polarized mosfet. Imagine the gate drains allways to the soruce, therefore the gate discharges to gnd. connect an other mosfet (inactive) with soruce to VCC and connect the gates together. This should result in the charge draining to GND be resupplied by the other mosfet leaking VDD to Gate. Anyhow, no need to be extra fancy here, the effect works
Registered Member #162
In the late '70's I was trying to measure photodiode currents in the sub-pA range using a parametric amplifier, fA leakage currents. I could not get it stable, then one day standing about 1yd away I moved my hand, and the meter needle flew across the dial. The plethora of charges on me, my clothes, anything, everything, was enough to induce fA currents in the circuitry... I never managed to make it viable.
I'm not expert in this are but I would not use insulators (plastic box etc.) too near to the electrostatic probe electrode as accumulated charge causes drift. But
The probe is perfect - it does what it is meant to do - nice.
P.S. I suspect that it would sell better as a ghost/ufo/cosmic-rift detector.
Registered Member #72
I'd second Sulaiman's concerns.
I read an article by Bob Pease (RIP) a while ago (if you don't know his stuff, get googling. If I called him 'the Feynman of analogue electronics', I'd be exaggerating, but not by much) that talked about measuring fA leakage on an electrometer amplifier input. To do this, he used it as a fed-back integrator, with a low leakage capacitor, and measured the drift.
Problem one was the physical volume of the capacitor, the bigger the cap the more frequently cosmic ray strikes generaterd charge pairs in the volume, causing the integrator output to jump.
Problem two was that everything had been built on PTFE, and charge stored on the surfaces took minutes and hours to move around, disturbing the readings while they did. Covering as much of the unnecessary insulator surface with alli foil mitigated that.
