  • Guests: 22
ramses (16)
Arcstarter (31)
Zak (15)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
XRay Transformer Questions
Isotopicgoose
Thu Feb 15 2018, 01:04AM Print
Isotopicgoose Registered Member #61577 Joined: Wed Apr 19 2017, 12:13AM
About a year ago I acquired an XRay transformer and recently decided I want to do something with it in a project. I'm looking for info on what the connections going into the transformer are exactly. They are XS1, XC XS2, MA-, MA+, G, P1, and P2 as in the photo below (XS1 is just out of the frame). I'm fairly certain P1 and P2 are the primary and G is the ground. While I assume XS1 and XS2 are some sort of secondary and MA- and MA+ might be for current measuring, I'm not certain. Any help is appreciated, cheers!
A85521cad025b5ccb4c96b90772d3d5f
johnf
Fri Feb 16 2018, 06:21AM
Ma+ Ma- are for a meter this must be in place with protection in case meter goes open circuit.
use a meter to determine what goes where when you short Ma+ to Ma-
AndreiRS
Wed Feb 28 2018, 03:54PM
AndreiRS Registered Member #62109 Joined: Sun Jan 28 2018, 10:00PM
Hmmm. I just don't know. But with a ohm meter or a simple multimeter things will get a lot easier. The primary inductance and resistance will be way lower than on the secondary.
Kolas
Wed Mar 14 2018, 01:54PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
Is there a name plate? If so, there's a chance there is a simple wiring diagram on it.
X is generally used for the secondary winding of a transformer... and H is used for the primary when it's a stepdown.
I think there is a good chance that XS1 and XS2 are indeed your secondary windings, and XC should be the center tap of the secondary. If this is a true step up xray transformer, the resistance of the secondary should be so high that it is measurable. In this case, expect the resistance of the secondary to be MUCH higher than the primary. It would be safer to short any other windings while testing resistance because of the possibility of this thing acting like a pulse transformer.
Be careful, and good luck.
AndreiRS
Wed Mar 14 2018, 09:48PM
By the way I think these things output DC if I'm not wrong. There should be some big glass diodes setup inside. And lots of oil.
johnf
Thu Mar 15 2018, 06:16PM
AndreRS
Some x-ray transformers do have diodes, others use the x-ray tube itself as the rectifier so it could go either way
AndreiRS
Thu Mar 15 2018, 11:23PM
Oh, thanks johnf.
