  • Guests: 30
a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
05/09 Coronafix (51)
UV lines of mercury spectra at a ZnS screen
Physikfan
Fri Feb 09 2018, 03:19PM Print
Physikfan Registered Member #60240 Joined: Mon May 16 2016, 07:01PM
The spectra are Hg spectra, photographed from a Canon 10D, with increasing intensity from top to bottom, light source is a Hg high pressure lamp, the entrance slit is imaged with a quartz lens via a reflection grating on a zinc sulfide screen:
IMG 9588ZnS1s1000x172
IMG 9589ZnS6s1000x184
IMG 9591ZnS6s1000x184
Plasma
Fri Feb 09 2018, 07:11PM
Plasma Registered Member #61406 Joined: Thu Jan 05 2017, 11:31PM
The Hg lamp is a growing lamp for the vegetable stack, the green growing phase, its mostly blue colour, the uv spectrum is below that, but your getting swamped by the ratio of uv to 420nm,try using a class A uv light from a suppler and then calibration from there
Physikfan
Fri Feb 09 2018, 07:33PM
Hi Plasma
I did not understand your response.
"but your getting swamped by the ratio of uv to 420nm,try using a class A uv light from a suppler and then calibration from there"
Please, could you explain me your answer one more time?
The purpose of my research here is to study different screens for their sensitivity to UV radiation.
This is a comparison between a of zinc sulfide screen to the already used UV screen
Zinc sulphide screen:
UV screen
1s1000x164
IMG 9593UV1s1000x166
With comparable intensity of the visible lines, the UV screen shows significantly more UV lines.
Plasma
Mon Feb 12 2018, 04:24AM
Wouldn't the zinc sulfide reradate the ionizes from the uv at a different frequency.
get just a uv source, a lighting supplier can sell you just a party lamp, which would have a lot less noise on the ouput
