  • Guests: 35
Steve Conner (46)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Ye good OL BRISG Tesla Coil
Sat Nov 18 2006, 10:05PM Print
One great thing about being a seasoned member of this fine brotherhood of high voltage pulsed engineers is, that if the recipe starts with:
"You take an OLTC", well then I can go to the shed and drag out an old battered prototype.
And when the recipe continues:
"Then sprinkle with SISG topping", then I have recent experience with that too.
Ok, Enough hand waving.
The guts of the product, the Off Line BRIck siSG Tesla Coil, can be seen here:
To get the gate of the CM600 open, I used a 36V TVZ, a 200nF cap a 5Ohm Gate charging resistor and a 750ohm gate discharge resistor. The result can be seen here:
Resonant charging as usual,
Does it make sparks, oh yes! And this coil is one that appears to favour high break rates as seen on this short video, where I sweep from 63BPS to 1250BPS
Cheers, Finn Hammer
Sat Nov 18 2006, 10:33PM
fun stuff
Pretty good for an offline coil!
Although I beg you to get a new file hosting site, needing to type in a code, then wait 30 seconds, AND they only give you 20KB/s mistrust
Terry Fritz
Sun Nov 19 2006, 03:48AM
Hi Finn,
Wild!!!!!! Looks like about 30+ inches!!
I mirrored the movie at:
If one frame-by-frames the arc, there are some neat things going on there too!!
Looks like there might be some "cork screw" effects or something like tube coils...
Very cool!!!
Cheers,
Terry
Sun Nov 19 2006, 10:50AM
Daniel Uhrenholt Registered Member #125 Joined: Fri Feb 10 2006, 01:52PM
Nice work Finn!!!
I like the BRISG idea cheesey
You now know that the SISG work on some fairly big IGBT bricks, I wonder where this is going tongue
Keep up the good work, it`s very cool.
Cheers, Daniel
Sun Nov 19 2006, 03:45PM
Terry Fritz wrote ...
This might be explained by the near-CW operating condition:
tribledotting smile wrote ...
Give me a break.
This coil is merely coasting along, as shown here, Ipeak=2.6kA
Cheers, Finn Hammer
Terry Fritz
Mon Nov 20 2006, 10:35PM
Hi,
Wow! Yes indeed! 1200BPS is much higher than we are used to wink
Mark has had his SISG running with 14.4kV firing voltage (16 sections x 900v) and Finn has gotten to 2600 amps. That is over 37MVA!!! With Finn's trigger system now, the only thing the SISG has not done is quenching (we don't seem to miss it...). We may not have quite the control of a DRSSTC, but pretty close smile I note Finn has not blown any IGBTs either unlike the DRSSTC systems tend to until they are all figured out cheesey
I am so happy that all this SISG stuff is working so well!!! amazed Weeeee!
As the saltwater cap is cheaper than MMCs, I suppose the "spark" gap will still be cheaper than SISG type systems... But "spark" gaps are sort of a "dead" technology now...
Cheers,
Terry
BTW - I also like FireFox 2.0's new inline form spell checking wink It helps "me" a lot here cheesey
Tue Nov 21 2006, 09:29PM
I have a Stephen Conner Controller (TM), and it has full quench control. Based on the experience with it, I came to the conclusion, that there is no advantage in premature quenching (Quenching before the coil does by itself). We may think a coil performs better if it quenches at the first notch, and then jumps to the conclusion that if we force 1st. notch quenching then we get this good performance.
We don`t. The top load streamer complex is unable to process the power, that`s why it keeps ringing back and forth.
Some coils naturally quench early, (my old Ambassador was one) the power is effortlessly transferred to the streamer and I hope we can find out how to design coils that do so.
I guess the key word is impedance matching, and with the progress you have done in streamer modeling, I hope for a breakthrough in that line of design.
That`s right, the SISG crowbar feature does it`s trick! cheesey
And it is really funny to experience the change in coil behavior, when I turn the voltage up to a level where the trigger system is bypassed by the SISG voltage breakdown limit: The coil goes bananas amazed . The fuses get hot! cry . The lights brown out sad . The fuses blow mad . The lab gets black. I got a kick! tongue
Cheers, Finn Hammer
Tue Nov 21 2006, 10:30PM
Hi Finn,
My experience with the OLTC controller was much the same as yours: When the coil is making sparks, the accurate control of quenching doesn't seem to matter much. So I think for practical purposes, Terry's new SISG thing, plus your SCR trigger circuit, is as good as my OLTC controllers ever were. Better even, since you don't have to worry about misquenching, and you can stack them to switch crazy voltages! suprised
finn wrote ...
The coil goes bananas . The fuses get hot! . The lights brown out . The fuses blow
Does that mean I was right, when I said a SISG without triggering would be unstable with DC resonant charging? At least it protects itself from overvoltage with style wink
Wed Nov 22 2006, 09:32PM
Steve Conner wrote ...
I guess so.
The break rate increases to a point, where the power supply is unable to maintain the voltage, then there is a short break and it starts over again. Huuuiiiit, huuuiiit, huuuiiit amazed
I tried this with a couple of the SIDAC`s shorted out, and the breakrate increased to 2564 bps @1200Apri
Cheers, Finn Hammer
Terry Fritz
Thu Nov 23 2006, 01:50AM
I am not sure I would call it "unstable". The SISG, or OL-BRISG, is still firing right on time exactly when it "should" smile
With the PIRANHA charging system, it is a bit "chaotic" but still doing just what it is supposed to do.
As long as it fires when ever the voltage reached the firing voltage it is fine. It is just a matter of how fast you can charge the system and how cool you can keep the IGBTs. In the case of those giant CM600's, they probably are not even warm yet wink)
If you fire so fast that you get into the region before the SISG turns off, then I guess you would have a "power arc" type of situation where it really never turns off (but it might be able to "re-fire"). I guess one could consider a case where the thing is running in a pseudo CW mode too... But I don't see an obvious way that would work other than pushing the firing rate right into the ring down time. Like it would re-fire on every third cycle or something. But rates like that probably heat the silicon way up.
Cheers,
Terry
