  • Guests: 24
Colin 99 (53)
05/12 Colin 99 (53)
05/14 hvguy (41)
05/14 thehappyelectron (14)
High pressure from electysis to feed between sparkgap
Plasma
Mon Jan 01 2018, 01:47AM Print
Plasma Registered Member #61406 Joined: Thu Jan 05 2017, 11:31PM
Hi I've set up a 60kv supply, and plan when the surface tracking is sorted to move it up to 90kv and a 20nf bank.
the question I would like to ask is how to build a electysis setup to reach 50-500bar,in a 50mm3 chamber, I can get 70bar from oxygen tanks but high will be impossible to source off the shelf.
Will a hydrologic pressure gauge rated for 9000psi work for gas, with some type of piston.
at high voltage are there new effects that will possibly be a health assered.
Thanks
Mon Jan 01 2018, 08:32AM
I briefly investigated high pressure water electrolysis many years ago, so, from memory;
The coulombic efficiency (Faraday constant) does not change significantly with increasing pressure.
The rquired voltage does increase with increasing pressure, but not dramatically,
I think about +3% at 200 bar ... but don't quote me.
Given that we rarely achieve a low overpotential
(ideally 1v23 total cell voltage ... good luck with that !)
... you will not notice much difference between 1 Atm nd 500 Atm
- except of course that the volume of gasses produced will be inversely proportional to pressure.
