  • Guests: 32
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
Universal half-bridge driver
profdc9
Tue Dec 19 2017, 05:49PM Print
profdc9 Registered Member #58522 Joined: Tue Mar 15 2016, 08:33PM
I laid out a circuit board for the half-bridge driver I designed that uses a gate driver transformer, the one in this document:
A picture of it is below. When I get some time I'll build it up and test it. It uses the UCC37321 so it should be able to drive decently powerful IGBTs, and possible SSTC and induction heaters and the like with an adjustment of frequency.
Dan
Driver
woodchuck
Wed Dec 20 2017, 04:01AM
woodchuck Registered Member #39190 Joined: Sat Oct 26 2013, 09:15AM
Quite a nice document you've put together. I look forward to seeing your new board in operation.
profdc9
Thu Dec 21 2017, 05:19PM
It already works. I built it on perfboard and it works fine. I am laying out a circuit board because wiring it up by hand is a pain.
I reduced the board size to save some fabrication money and space. The latest is below. I added an LED that flashes when the overcurrent condition occurs, and a way to externally disable the gate driver, so that for example you could turn it on and off to make a musical SSTC.
Dan
V2
