  • Guests: 25
05/11 ramses (16)
05/11 Arcstarter (31)
05/11 Zak (15)
DRSSTC.5 current transformer
matt0852
Sun Dec 10 2017, 03:01AM Print
matt0852 Registered Member #61299 Joined: Thu Nov 17 2016, 11:17PM
Hi everyone,
I am planning to construct Steve Ward’s DRSSCT.5, using his UD1.3
Coil specs are almost the same as his coil.
Is it possible to use this 1:1000 100A current transformer: Link2 instead of winding my own CT for OCD and primary feedback?
Thanks!
GrantX
Sun Dec 10 2017, 05:24AM
Unfortunately that CT is only specified for 50/60 Hz use and won't work. You will need a ferrite-core CT designed for much higher frequency, Steve states that DRSSTC.5 operates around 350 kHz.
matt0852
Sun Dec 10 2017, 08:24AM
Guess I'll have to wind my own current transformer then. Is an initial permeability of 1500 sufficiently high for a CT? I happen to have 4 of these lying around: Link2
dexter
Sun Dec 10 2017, 07:13PM
EMI Suppression cores don't work either... learned this the hard way...
you need 3C90 or 3E25 core material
matt0852
Mon Dec 11 2017, 01:23AM
Side query, is this a good core for the GDT? Link2
Alex Yuan
Wed Dec 13 2017, 12:36AM
Alex  Yuan Registered Member #9614 Joined: Mon Jan 14 2013, 10:00PM
Look for N30/N87 type material, I use B64290L0674X087 and B64290L638X87.
